2002 FatBoy Problems Help!
Old Aug 30, 2008 | 10:57 AM
had2haveaharley's Avatar
had2haveaharley
4th Gear
Thanks for all the help so far. I have to go off to work. Will check posts this evening and see for suggestions. thank again!
had2haveaharley!
Old Aug 31, 2008 | 08:57 AM
had2haveaharley
4th Gear
Default security system update ..more help please
Hubby followed instructions, reset security system. Bike responds to fob. Now what happens is...Bike will turn over (some headway!) However, the electronic or fuel system must be shut down or not working. You can't hear the inital startup of the fuel injection. Also strange- at some point the turn signals flash 5 times. He can turn it on, it turns over, but u can't hear initial fuel system start up, it turns over but doesn't fire up. Any new suggestions now? Thanks
Old Aug 31, 2008 | 09:33 AM
tmitchellof PG's Avatar
tmitchellof PG
Is your kill switch in the run position?
Now that you know how to get your fob to activate and deactivate the security system, try another disconnect of the battery. It might just reboot the system.When disconnecting the battery, the easiest method is to disconnect the ground strap from the frame just forward of the battery. This way you are not constantly messing with the battery terminals.
I have a 2005 SE Fat Boy, with an owner's and a service manual. It does state after a battery disconnect, you are suppose to follow certain steps. I never did this, the 4 or 5 times my battery has been disconnected and never had a problem with the security system.
I could copy the instructions and e-mail them to you, if you need them.
Tom
Old Aug 31, 2008 | 11:17 AM
had2haveaharley
4th Gear
Kill switch is in run position. Checked - spark plugs are getting spark - unhooked the battery and redid it...still nothing. It turns over. (sigh) Wondering now if it's something else. We checked the wires that go the fuel injection with the meter. They read right according to the meter. Haven't checked the coil...can't find a place on here that tells how yet lol At a loss for what else to do , other than check the ignition system and don't know how to do that either. Open to suggestions. Short of back on the trailer and back to the dealer....running out of "shade tree options"
Old Aug 31, 2008 | 11:25 AM
had2haveaharley
4th Gear
sorry spark plugs not getting spark!
flyweed
Aug 10, 2017 04:47 PM
Broomhead
May 25, 2014 06:13 PM
jaysfatboy
May 10, 2014 05:51 PM
Choney
Apr 12, 2012 12:56 PM
heybaylor
Oct 24, 2010 12:37 PM
