Softails running hot?
Old Oct 15, 2004 | 11:43 PM
harleybiker's Avatar
harleybiker
Default Softails running hot?
Heard that Softail models run hotter than other Harleys. Fact or fiction?
Thanks.
hb
Old Oct 16, 2004 | 01:54 AM
Lovetoride's Avatar
Lovetoride
Default RE: Softails running hot?
Mine seems to be running at a normal temp. Did you read that in a magazine?
Ryan
Old Oct 20, 2004 | 08:14 PM
BClem's Avatar
BClem
Hotter? Yes probably, and for a shorter life expectancy than the 88 (not 88B) because of all the extras going on in the B model. You should get a reputable "Dealer" to check that out. (Harley is having touble finding reputable dealers too!) They have all the answers...
BClem
Old Dec 26, 2004 | 01:41 PM
Battersea's Avatar
Battersea
3rd Gear
Here's my £'s worth (sorry $'s worth), all 88's run slightly hotter than the EVO, more like the Shovel. This happens for different reasons but it does seem to be the case. Most people accept that a Shovel benefits from an oil cooler and so it is with an 88, A or B. The UK is not known for high temperatures but on a good summers day and in traffic my Fatboy runs very hot, definitely needs a cooler.
Old Dec 26, 2004 | 08:43 PM
pococj's Avatar
pococj
From what I've read on the Twinkie engines, Softail or otherwise, they do run hotter than an Evo. I think most of it is due to the oil jets that squirt oil directly on the lower (or underside? can't remember exactly) area of the pistons to aid in cooling them. That makes the oil hotter as it is doing one of its jobs in removing heat. I s'pose there might be other factors involeved, but I ain't heard of 'em.
As long as you are running a synthetic oil, you really don't have to worry about the extra heat. They can run at the ragged edge of regular dino oil breakdown temp, especially in the heat of southern/western summers. I know several guys who've had their engines drop back to 1 cylinder during a hot summer parade.
As stated earlier, an oil cooler is a definite plus.
Old Dec 28, 2004 | 02:54 PM
hdmd88's Avatar
hdmd88
Stage IV
Fiction....the TWIN CAM has more fins that any other harley in history, the piston jets cool the engine by 30 degrees and the piston thrust surface is coated with Moly Disfulite for less friction.
Old Dec 29, 2004 | 05:43 PM
Battersea's Avatar
Battersea
3rd Gear
Sorry to have to disagree but, 1> the exhaust valves on the 88's are small (smaller than the EVO) even though it has more cubes 2> this means exhast gases are restricted on exit so the pistons hold more heat, this is probably to aid cleaner emmissions, so 3> they put oil jets to squirt on the underside of the piston heads to take some of the heat away, 4> this increases oil temp hence the need for an oil cooler, IMHO.
Fritzables
Apr 22, 2014 05:37 PM
jfsgb
Shovelhead
Feb 22, 2013 06:29 PM
chugchug
May 9, 2009 10:13 PM
fatboy4ever
Oil Archive (no new posts)
17
May 14, 2008 11:26 AM
easyglider
Nov 15, 2006 03:39 AM
