2002 fluid changes-heritage standard
Old Sep 12, 2008 | 07:45 AM
corona1cal's Avatar
corona1cal
Unhappy
deleted
Old Sep 12, 2008 | 09:33 AM
oldgeezer's Avatar
oldgeezer
Your transmission drain plug should be between the shocks on the bottom of the transmission. It should be the same type plug as the oil plug. Break it loose with a 5/8" socket then unscrew it the rest of the way with an allen wrench.
The primary drain plug is a small plug at the bottom of the lowest point on the outer primary cover. You'll need to pull either the derby cover or the inspection cover to refill the primary with oil. If you pull the derby cover, you'll need the bike upright (put a short 2*4 under the side stand) to get the correct amount of oil in the primary.
Old Sep 12, 2008 | 07:17 PM
corona1cal's Avatar
corona1cal
deleted
Old Sep 13, 2008 | 01:36 AM
shubble72's Avatar
shubble72
There is a inspection cover in front of the clutch cover its got torx head on the bolts.
maineultraclassic
Sep 15, 2016 06:25 PM
ffron69
Jun 18, 2015 06:23 AM
newjack66
Sep 4, 2014 04:55 PM
kountry
Apr 16, 2011 08:00 PM
spry1500
May 25, 2009 10:56 PM
