please help with primary oil change
1. how to get that one bolt out that is starting to strip?
2. can I just fill through the inspection cover, and if so how do I know how much to put in?
3. for the drain plug it says to screw in to a certain measurement of the drain plug sticking out (I forget exactly) - is that correct? Won't it back out & leak? It is literally in there finger tight, doesn't seem right does it?
Thanks,
Ron
00 Fat Boy
Do you remember how tight it was when you took it out. I think you might be confusing the adjustment of the primary chain adjustment shoe with the drain plug.
And yes you refill through the inspection cover.
Jim
A standard plug (the one that uses the o ring) will have a specific torque reguirement.
The tapered plug has a clearance measurement (I`m not sure how accurate that method is, I just make sure it is snug, that`s not much help is it...?).
Because of the taper, installing it in too deep will crack the case.
Removing the derby cover from the primary before draining the lube is the smart way to go, as you are finding out.
This practice is good to keep in mind when working on any type of machine, make sure the filler cap, plug, cover etc can be removed before draining the lube.
You gotta get the derby cover off, don`t try working around a bad screw...https://www.hdforums.com/forum/prima...by-covers.html
You don`t fill through the inspection cover, you fill through the derby cover opening so that you can see when the lube is at the proper level.
Fill the primary until the level of the lube is just touching the clutch shell, with bike straight up, make a note of how much it took, and you will know exactly how much to have on hand when doing service in the future.
This is the correct level for all big twins with a wet clutch (mid `84 and later).
Underfilled is better than overfilled.
Most likely cause is your torx bit isn't the exact size - my buddy's cheap set didn't have the exact size but a better set from Home Depot did. I don't recall the number at the moment. The screws have a little loctite on them so they are tough to get started. If yours isn't quite stripped you can try getting the right bit if your bit is loose.
To fix the problem I used a slightly bigger bit and hammered it in and removed the screw, then got a new screw. If you have an impact driver this is a great use for it. Or a battery impact should do it. I was at a buddy's who started the job and didn't have these tools like I do, so a hammer got it wedged in there and I got it out with a socket and ratchet. Not a big problem. HD sells a chrome screw set if I recall, and you can get them aftermarket and Ace hardware usually has them (chrome too). I had one in my box.
Jim
I put the allen socket in and turned it by hand - the manual says a heath dimension that the plug needs to stick out but there isn't a torque spec. I am out of town now but read it a ton of times, just didn't seem right.
Thanks I am just leary to go by "spec" alone, it also says 3.5 quarts of engine oil and took just under 3...
Thanks Dan, it just makes me nervous not having that plug tight....
I plan on getting the bolts out just wanted to get the fluid changed and buy some time to work on the f'd p up bolt
Thanks, it actually is the correct torx, the other ones were tough to get out but this one is starting to slip & I don't want to totally strip it out. I was also thinking about an impact...
I just swapped all three holes in my buddy's 03 for the first time since new (it's low miles) and the primary drain was definitely 27 torx, with thread tape on it. I tightened it up until it was as we used to say at the shop I worked at, "good-n-tite" (keeping it clean). It's a tiny bolt so it doesn't need much torque.
