Vibrations...noises?
Old Oct 27, 2008 | 02:45 PM
jmg343's Avatar
jmg343
Default Vibrations...noises?
When I am riding I hear some vibrating noises coming from right around my air filter area and another one coming from the area underneath my speedometer. I have seached high and low for a loose bolt or anything of that nature and have come up empty handed every time. Sounds sorta like a washer on a bolt that isnt fully seated. Anything in those areas that has a reputation for loosening that I could check? Could just be my little brain rattling around in my big 'ole head!
Old Oct 27, 2008 | 03:32 PM
oldgeezer's Avatar
oldgeezer
Did you pull the air filter cover and check the banjo bolts?
Old Oct 27, 2008 | 06:16 PM
jmg343's Avatar
jmg343
Yes, last time I cleaned the filter...they were tight.
Old Oct 27, 2008 | 06:31 PM
tmitchellof PG's Avatar
tmitchellof PG
First thing I would check is the exhaust. Make sure everything is tight and that there isn't any portion of the pipe/muffler touching the frame.
Tom
Old Oct 27, 2008 | 09:40 PM
anubisss's Avatar
anubisss
Heat shields have been known to come loose and cause annoying rattling as well...If you really want to figure out what it is get a buddy to sit and listen while you rev the bike till you pinpoint what it is.
Old Oct 27, 2008 | 09:42 PM
DaddyKnuck's Avatar
DaddyKnuck
You don't say what model you have. Is the noise more noticeable when the gas is low? If it's an EFI bike there is a bunch going on inside the tank. I was amazed at the difference in engine noise bounced back from the windshield on my new bike, while the bike is very quiet without it.
Old Oct 27, 2008 | 10:51 PM
sonar_chris's Avatar
sonar_chris
I will bet that he has a bike with fork tins, and that is what is rattleing. Next time you hear the rattleing, take your left hand and grab the fork tin just in front of the risers and I will be the rattle goes away.
Old Oct 28, 2008 | 08:27 AM
jmg343's Avatar
jmg343
Ive got a softail custom. The rattle aint that bad. I dont hear it if I am stopped at a light and rev the motor. I hear it only when Im movin down the road. Its not bad either, Im being nitpicky. To really hear it Ive kinda gotta turn my head sideways. Just the wind from noise from my helmet alone is enough to pretty much drown it out.
Old Nov 5, 2008 | 10:39 PM
jmg343's Avatar
jmg343
Ive searched high and low all to no avail. Im starting to think now that it is more of a whistle than a vibration. Is it possible that the wind passing through/over my cables is making a whistling noise from the wind?
Old Nov 6, 2008 | 08:22 PM
OOORAH's Avatar
OOORAH
Try the mufflers ! Pull the baffles out ,it always makes the rattles go away.
Didn't mean to be snip but almost every time I ride my H.D. it makes a few new noises. They are rarly the same from time to time so I only address the ones that hang around the longest ....
