Oil filter question
Old Nov 24, 2008 | 09:23 AM
DaddyKnuck's Avatar
DaddyKnuck
If you're not worried about pissing Momma off: steal or borrow her flexible cutting board. Works great to channel the oil into a pan and keeps everything neat. Actually, steal is better. They're only a couple of bucks and you're not going to want to eat anything cut on it afterwards.
Old Nov 24, 2008 | 11:38 AM
TequilaJohn's Avatar
TequilaJohn
Originally Posted by xxxflhrci
It is not necessary to add oil to the filter before you screw it on.
Bad advice. You should always "prime" yer filter before ya install it.
Old Nov 24, 2008 | 12:02 PM
ngoti8tor's Avatar
ngoti8tor
It's not necessay, but if you intend to keep your bike for a long time like I do, you're better off in the long run to fill the filter about half way (don't forget to rub a bit of oil on the rubber ring) before installing the filter.
This way the oil gets to your engine faster on the initial startup after the oil change (or "priming" as TequilaJohn says).
Old Nov 24, 2008 | 10:31 PM
niteowl02's Avatar
niteowl02
It looks like whichever method I use I'll have some cleaning up to do. Oh well, I'll be saving some $$
deadman77
Oct 18, 2015 06:45 AM
Timpechos
Jul 5, 2013 10:14 AM
RoadKingHellas
Feb 10, 2013 12:24 PM
dwayne u
EVO
11
May 1, 2012 12:19 PM
murd
Aug 1, 2009 07:24 AM
