Replacement LED Blubs
Old Dec 1, 2008 | 07:01 PM
RobbAR's Avatar
RobbAR
Default Replacement LED Blubs
I want to change all my signal and running light blubs to LED's. I have read that if you have a solid state flasher you dont have to have the load equlizer but if you have the mechanical flasher you do. I have an "08" Fat Boy has anyone had any experience with changing all the signal light bulbs to LED.
Old Dec 1, 2008 | 09:14 PM
ChromeJunkie's Avatar
ChromeJunkie
I don't know about the 08's, but mine is an 06 and needed a load equalizer when I switched to LED's.
Old Dec 2, 2008 | 01:12 AM
Cheesecake's Avatar
Cheesecake
my 08 XB needed a load equalizer.... I would think your Fatty would also...
Old Dec 2, 2008 | 07:20 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Some bike's seem to need it and others don't. All Harley's lights (turn) have been using the same type of electronic signal control system for a number of years now. But there still doesn't seem to be any rhyme or reason for why one bike needs it and another doesn't.
So I think your best bet would be to plan on getting one. If you get it from someplace like Biketronics they are often set up as a simple plug and play deal.
Check with www.Customdynamics.com they have a good selection of some of the best bit's and pieces needed to get LED's on your bike.
Old Dec 2, 2008 | 07:27 AM
tk353's Avatar
tk353
kuryakyn makes a solid state adapter for the rear that work either kind of bulb with no load needed
Old Dec 3, 2008 | 12:39 AM
Toneaero's Avatar
Toneaero
I didnt need one for my 08 Rocker. The rears came stock with LEDs but I wanted the front signals changed out to LEDs. When I swapped out the front bulbs with LEDs, it flashed at a faster rate at first. After holding down the hazard lights and turning the ignition off and on, the bike "learned" to compensate for the lower current draw. Now my lights blink at a normal rate and I have all LED lights now (minus headlight). Maybe all 08s have this learning feature....
Old Dec 4, 2008 | 08:42 PM
RobbAR's Avatar
RobbAR
Thanks for the help
Old Dec 5, 2008 | 01:18 PM
Archer1968's Avatar
Archer1968
citoriplus is correct all my lighting comes from custom dynamics, also if you have an alarm system you have to use a special load equalizer. kuyakyn is also a good place to get it.
Old Dec 5, 2008 | 05:52 PM
Buddha4's Avatar
Buddha4
I am running Adjure turn signals in the front and a Heavycycle rear tailight w/turn signals built in.
Old Dec 5, 2008 | 07:55 PM
Alain's Avatar
Alain
you got any pics of those front LEDs in action ???
Las Vegas Jim
Electrical/Lighting/Alarm
15
Jun 3, 2019 04:26 PM
SteddyTeddy
EVO
Jan 23, 2019 09:17 AM
acd118
Nov 30, 2015 11:53 AM
harley012
Aug 4, 2013 10:59 AM
fishboy
May 29, 2008 12:04 AM
