98 softail won't turn over
Apr 9, 2006 | 08:49 PM
5th Gear
I have a 98 heritage that has some custom work done to it, a mid range cam kit was installed two years ago.
I have replaced the starter with new parts and installed a new battery, when I try to start the bike I only get a spinning, It will not crank over? any suggestions?
Apr 9, 2006 | 09:29 PM
RE: 98 softail won't turn over
Drain the primary, pull the outer cover, and see if the starter engages the ring gear on the clutch hub. Sounds like it ain't kicking it out.
Why'd you replace the starter?
Apr 9, 2006 | 10:21 PM
5th Gear
The parts in the starter were replaced, it was bench tested and was ok???
I also replaced the pinion??? gear.
Apr 10, 2006 | 12:07 AM
Starter clutch...
Apr 10, 2006 | 06:36 PM
5th Gear
Thanks...
any idea on the cost to replace
Apr 10, 2006 | 06:38 PM
Harley gets @119$ fot the whole thing.
Apr 10, 2006 | 06:51 PM
5th Gear
Thanks for your help
Apr 10, 2006 | 10:23 PM
Welcome!
scot210
Oct 21, 2017 08:35 AM
customsoftail200
Oct 18, 2011 04:06 PM
Evil Evo
Jul 21, 2010 05:32 PM
Bullys FLSTN
EVO
Sep 5, 2009 06:36 AM
steve2107
May 13, 2009 02:01 PM
2000 ,
2005 ,
98 ,
clutch ,
crank ,
gears ,
harley ,
softail ,
springer ,
star ,
start ,
starter ,
wont
