Turn Signal Trim Ring Kit Installation
Old Dec 18, 2008 | 08:41 PM
Dustmaker's Avatar
Dustmaker
Default Turn Signal Trim Ring Kit Installation
Hi All.....just got some great signal trim rings from a member. Question is, how in the h3ll do they go on......lol
These are for flat lenses, if that makes any differences.
Thanks!
Old Dec 18, 2008 | 09:00 PM
Alain's Avatar
Alain
hey bro, if you look on the bottom of the actual turn signal you will see a small whole where you can stick a screw driver or something to that nature and pop off the lens that's there now. then all you have to do is replace it with the one you bought.
really simple.
Old Dec 18, 2008 | 09:09 PM
Dustmaker's Avatar
Dustmaker
really simple.
LOL......not the lens....I got those off...wanted to know how do I get the new trim ring on?
Sprint gpt me on the right track. I will show all shortly
Old Dec 18, 2008 | 09:36 PM
conroskie's Avatar
conroskie
There should be an "O" ring that you need to put in behind your lense. This will seal it from water and also create a gap wide enough for you to snap the ring behind your lense. What I did was keep my lense a little loose, then snuged it up after I got the lense on. Hope this helps,
Old Dec 18, 2008 | 10:14 PM
Dustmaker's Avatar
Dustmaker
Here are a couple pictures of them installed.
OK, I still need to tighten the lens to the signal housing. I can not get the screw driver in the screw to tighten them up. So how do I get to the screws???
Old Dec 18, 2008 | 10:18 PM
Alain's Avatar
Alain
sorry bro, i'm retarded today
Old Dec 19, 2008 | 01:09 PM
Dustmaker's Avatar
Dustmaker
Still ned help.......I can not get the lens tight, because I can not get the phillip screw driver on the screws???
So what is the secret to getting the lens tight and the ring tight too?
Old Dec 19, 2008 | 01:30 PM
Mordrapheus's Avatar
Mordrapheus
Side tip: cover up your license plate number when you take a pic where it can be seen before you post the pic....you never know who is trolling the site.
_Daswine_
Softail Parts
Apr 3, 2014 07:49 AM
ny2az
Touring Parts
Apr 25, 2012 12:51 PM
Memo7070
Apr 5, 2012 12:49 PM
medic1555
Touring Parts
Sep 17, 2011 07:39 PM
kaosj
Feb 1, 2009 05:42 PM
