Internal wiring handlebars
Old Jan 7, 2009 | 04:01 PM
rockercsx's Avatar
rockercsx
Default Internal wiring handlebars
Has anyone got any insight on internal wiring handlebars? I was considering rewiring my 2008 Deluxe. Do you need specific handlebars to do this?
Thanks,
Old Jan 7, 2009 | 04:12 PM
Dagerazod's Avatar
Dagerazod
youd need dimpled bars, or to dimple yours
Old Jan 7, 2009 | 05:11 PM
ronyd's Avatar
ronyd
Yep, dimpled bars. I used WildOne 504 Chubbys on my 07' Deluxe. If you need guidance on how to install and rework the control cables, fell free to ask. Installed bars, SS cables, tach, extended control wiring last winter. Will look great...
Old Jan 7, 2009 | 07:38 PM
KumaRide's Avatar
KumaRide
Drilled some holes in stock Heritage bars and wired them internally. They were dimpled.
Old Jan 7, 2009 | 08:03 PM
wildman67's Avatar
wildman67
Drilled mine stock bars out with a half inch drill. work well so far!
Old Jan 7, 2009 | 08:07 PM
Alain's Avatar
Alain
what do you guys mean by dimple the bars?
Old Jan 7, 2009 | 09:01 PM
Soul_Cal's Avatar
Soul_Cal
This web page should answer your question:
http://www.sideroadcycles.com/Americ...r_Options.html
I don't think bars need to be dimpled, just drilled for internal wiring.
Old Jan 7, 2009 | 09:25 PM
57RebelRocker's Avatar
57RebelRocker
you will see a dimple in the bars alain
Old Jan 8, 2009 | 11:13 AM
XARAN's Avatar
XARAN
Not to hard of a job. if the bars are not drilled you will need to drill them and make sure that you smooth out the edges of the holes. Use a vacume cleaner to pull a piece of string thru the bars and tape the wiring to the sthing and ease it through the bars.
Some people just cut the wiring between the tank and forks and then splice it back after pulling the wires thru the bars, but I think its worth the time to disconnect at the connector under the gas tank and then pupp them through. If you need to exten the wiring you can eithe splice your self or J & P has wiring kits that extend the lenght using factory connectors.
Old Jan 8, 2009 | 05:16 PM
Alain's Avatar
Alain
got it, thanks guys
jett14
Aug 1, 2014 10:53 PM
Eds Wide Glide
May 18, 2014 06:29 PM
pipeyeti
Oct 18, 2013 08:48 PM
ronyd
Nov 30, 2007 06:51 AM
dr.phatkins
Apr 23, 2007 12:06 AM
