How Low
Old Jan 11, 2009 | 12:01 AM
bgibbster's Avatar
bgibbster
Default How Low
How low can you lower a softail(09 night train) with out going with an air ride system. I thought I read somewhere that someone had lowered their bike 4 inches, but I cannot find it anymore. Also what parts did you use? All I could find were 2" kits.
Thanks
Old Jan 11, 2009 | 02:36 AM
hpfatboy's Avatar
hpfatboy
Thumbs up
Use the HD low profile shock pt.#54651-05 $350.00 US this will give you approx. 2" drop, no lower. If you want it lower, probably have to go to air-ride system. then i guess you can go as low as you want, ex. fender resting on tire.
Old Jan 11, 2009 | 06:10 AM
Blk and Chrome's Avatar
Blk and Chrome
If you lower it 4" it would only be an inch or so off the ground. could be a tough ride. the most I have ever seen lowered was 2" Just go with that, if using the stock shocks and that low will be a rough ride. Your choice. Air ride is the best system as you can adjust the hieght with a push of a button
Old Jan 11, 2009 | 06:19 AM
George C's Avatar
George C
I just switched to air.
I have a set of Progressive 413 chrome lowering shocks for sale. Less than 2,500 miles on them $225.00 shipped.
Let me know.
Old Jan 11, 2009 | 07:46 AM
sledhead140's Avatar
sledhead140
i used the progressive 422's on mine and lowerd it 2in. theses shocks are fully adjustable for ride height and pre load so it rides real nice
Old Jan 11, 2009 | 08:19 AM
squirrelu's Avatar
squirrelu
I lowered my 2.5 in the back and 2" in the front on my deuce its a 02
Old Jan 11, 2009 | 08:58 AM
coop57's Avatar
coop57
If you lower more then 2" you run into potential belt clearance issues at the drive pulley.
Old Jan 11, 2009 | 11:52 AM
Lundee's Avatar
Lundee
I lowered mine 2.5" rear and 2 front w/ no problems. Little rougher ride but, not bad, buy shocks not bolts if your gonna go low its worth the extra money. I had this on my stock fender too. There is a bump stop between your swingarm and frame that keeps it from going to low. I've heard of guys shaving these to get a little more but I don't think there is a need w/ a stock fender.
Old Jan 11, 2009 | 01:17 PM
bgibbster's Avatar
bgibbster
Lundee or squirrelu, what shocks did you use to get 2 1/2" inches? All the ones I see just say 2inches. I was really only looking for 2 1/2 inches, but some bikes I see with 2 inch drop don't even look lowered and then some bikes just look slammed.
Old Jan 11, 2009 | 01:23 PM
97FXSTSB's Avatar
97FXSTSB
I went 2" with 422s (the recomended max).
