Well I started the process. I made sure everything was in order before I send it out to paint tomorrow. $250 for the fender I did not think that was to bad. I am in no rsuh because the weather here in MD sucks. I think it is gonna suck for awhile. I only had problems with a couple bolts otherwise everything came off pretty easy. I am not gonna put the lower half of the kit on because I am gonna put a stainless steel splash guard back there to protect my PCIII and compressor .Couple questions.... should i go buy a new wiring harness from harley for my new turn signals? For those that have this kit did you tap a hole at the top of the fender where the ECM harness goes on? Or did you just use the two screws at the bottom? Better pictures to come. Now I have all this stuff for sale. Alloy art turn signals. HD led tailight. Fender. Struts. Sissy Bar w/ hardware. few more things. https://www.hdforums.com/forum/motor...parts-pic.html. stuff for sale
Nah dave. It is a 06. Do you mean the struts? I did not have to cut the frame horns off. I still have the struts. Why would you want cut frame horns?
I thought it was a 08 which the frame horns are bolt on. I dont need the covers, its all good I got replacement horns that bolted straight up. Your scooter is going to look badass man.
