Just tore it down
Will have pix up later.
Working out a few details. Have possibly a spacer issue with front wheel. No leftover parts but somehow I end up with a 1/8" space between the fork leg and spacer on the non brake side. Races are installed correct. There were no shims/spacers used behind any of the races. And torqued the axle nut to 50ftlbs as required.
If I had only taken a close up pic before ripping it apart...oh well.
Then just have to finish the belt tension and should be done.
With the only exception of finding a plate frame for new bracket. Will take back off fender tomorrow.
Will take better pix tomorrow with fender off and hopefully get out if the weather permits.
