Question about pipes
Old Mar 21, 2009 | 10:07 AM
Fuco 12's Avatar
Fuco 12
Default Question about pipes
Will a set of V&H big Radius pipes that came off of a 2008 night train fit on a 2004 Heritage softail.
Old Mar 21, 2009 | 10:33 AM
Pork-Chop's Avatar
Pork-Chop
your best bet is to ask your local Stealer
Old Mar 21, 2009 | 11:30 AM
charliecfromSC's Avatar
charliecfromSC
6th Gear
they should fit, but they will likely have a threaded bung in each pipe for the o2 sensors, you would have to plug this up with a pipe plug or something like that
Old Mar 22, 2009 | 07:11 AM
tk353's Avatar
tk353
i believe the pipe diameter will be larger and designed for the 96ci engine
Old Mar 22, 2009 | 08:42 AM
Deluxechuck's Avatar
Deluxechuck
They do make bung hole plugs. They cost anywhere from $10 to however much you want to pay.
Anyhow, you best bet is to go to Vanceandhines.com, just shoot them an email and they will tell you if what you have will work with the pipes you have.
Old Mar 22, 2009 | 11:30 AM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Only diff is those bung holes. Cheap plugs and its all good. The same Vance & Hines Big Shot standards that will bolt on an 86 Evo powred softail will bolt directly up with on a 2009 96" Bones sans the plugs.
The real issue with pipes is that the larger motors want and need a larger exit diameter on the pipes. So for example a set of standard big shots will have a 1 3/4 head pipe and the same 1 3/4 exit diameter which is no good for the bigger TC motors and chokes em down bad. The newere pipes designed with the higher performing larger motors in mind have a stepped pipe design which will go from say a 1 3/4 head pipe to a 2 1/4 exit pipe.
I had a set of older big shot standards on my 05 Night Train that choked my bike and wouldnt let it make any power unless I ran them without baffles. The pipes bolted right up and were the same part number for my TC88 as they were for an old Evo! I had to switch up to a set of Big Shot stagereds with the larger exit diameter pipes in order to get the bike tuned and running properly.
Old Mar 22, 2009 | 01:16 PM
Fuco 12's Avatar
Fuco 12
The only thing I can see is that needs to be changed is the support bracket and plugging the bungholes. It looks to me that it will fit.
Old Mar 22, 2009 | 09:52 PM
Fuco 12's Avatar
Fuco 12
I it will help anyone else out. I talked to a tech from V&H and the big radius pipes off of the 08 night train will fit on the 2004 heritage. Plug the bunghoes for the O2 sensors and you are good to go.
Prowler_MC
Exhaust System Topics
Apr 25, 2014 06:55 AM
unscrew
Aug 18, 2013 08:32 AM
Rick S
Jul 9, 2012 05:21 AM
jm04
Aug 11, 2009 04:45 PM
wrenchguy24
Feb 12, 2009 05:42 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
