question about easy bracket install
Old Apr 15, 2009 | 12:49 PM
frozensoul's Avatar
frozensoul
Default question about easy bracket install
should get them this week ups if all goes well. when i install the strut bolts one at a time does my bike need to be jacked up? bags prob wont get here till next week but i would like to get the easybrackets strut bolts installed so ill be ready for the bags when the arrive. thanks for any help.
Old Apr 15, 2009 | 02:28 PM
ptl203's Avatar
ptl203
I didnt jack mine up and it worked fine. i would strongly suggest 2 people for the job. Maybe I am challenged, but I had a hard time evening the bags up with it on the kickstand and by myself. Good luck, it is an easy install
Old Apr 15, 2009 | 02:46 PM
frozensoul's Avatar
frozensoul
thanks, and ill use another body to help cause i know how some of the simple things can become a nightmare. thanks again.
Old Apr 16, 2009 | 01:17 PM
tk353's Avatar
tk353
did mine myself. sharpie and hold the bag where you want it. in my case it was a 2x4 in top of the pipe side and then match the other side. i got the forward brackets so i would not have to relocate the turn signals
Old Apr 17, 2009 | 04:37 AM
frozensoul's Avatar
frozensoul
forwards for me also, thanks
Old Apr 17, 2009 | 08:05 AM
spikehyre's Avatar
spikehyre
Strut bolt change was the easiest mod I have made. Very straight forward, one at a time, and no, not jacked up.
Old Apr 17, 2009 | 04:50 PM
Trailfndr's Avatar
Trailfndr
If you put the right hand easy braket, on the left of your bike...you can put a larger bag on without relocating the lights..I used the rear brackets on the wifes Deluxe, and put a fairly large bag on them. Works great.
(Yes, it was a mistake...but I'll stick with it lol)
Old Apr 17, 2009 | 10:23 PM
Yosemite's Avatar
Yosemite
I'm a vote for having it up on a lift.
I have a 200 rear on mine and there just isn't a heck of a lot of clearance between the sidewall of the tire and the bottom of the fender wall. Couldn't get my fat fingers up in there without some pain involved. Putting it on the lift allowed the tire to sag down a couple inches and that was all I needed.
And yes, one bolt at a time, torque and loctite.
Old Apr 17, 2009 | 10:48 PM
oct1949's Avatar
oct1949
put quick detach, back rest this winter and the install dir, is not as simply as then say...
rb1982
Oct 12, 2016 03:36 PM
smithrw
Sep 8, 2014 07:01 PM
bjv11383
Jul 2, 2012 07:35 PM
Mal74
Jun 16, 2012 04:13 PM
SeMiGoD
Oct 23, 2009 01:55 PM
