FLSTF front shock help
Old Apr 18, 2009 | 11:26 PM
mgmmgm's Avatar
mgmmgm
Smile Chrome siders
Yeah, the chrome sliders make the look of the Fatty. I kick myself for not doing it when I bought the bike, could have had 'er done right then. Crap.... Oh well.
Looking at these http://store.ricorshocks.com/Product...de=041-20-1001
I am still waiting for my heads to come back from Baisley's in Portland, so.... while the bike is in the shop..... here we go, lets just add some more goodies LOL.
But thanks for the e-bay links i will check them out 'cause I think the chrome front is kick ***.
Cheers,
Mark
Old Apr 19, 2009 | 10:44 AM
tlb's Avatar
tlb
Those are cool. I am not all that sure I need a "super" front end on a Harley. I mostly wanted to limit the amount of dip I would get when stopping. Hitting the front brake would cause the the bike to dip and effect the balance. The heavier fork oil solved the issue for me.
The chrome front end does make a fatboy pop.
I saw a thread awhile back, lots of guys would change the 07 sliders out for 08 sliders, to correct something. Have you searched for the reasons why?
Old Apr 19, 2009 | 02:36 PM
ChromeJunkie's Avatar
ChromeJunkie
Try changing the fork oil first and see how you like the difference. This is the least expensive and fastest change. I did this to my bike and there is a big change in the handling of the bike. If you don't like the difference, you are only out about $20, and can go back to the original fork oil.
Old Apr 19, 2009 | 08:40 PM
roysays's Avatar
roysays
how much oil do both the forks take?
also do you need to jack up the bike to take the pressure off of the forks to change the oil?
Old Apr 19, 2009 | 09:50 PM
tlb's Avatar
tlb
this is from the 06 softail manual should be the same since it is the same frontend
12.9 OZ,
1. Support the motorcycle so the front end is off the floor
and the forks are fully extended.
2.
See Figure 1·49 . Remove the fork tube caps.
3.
Drain fork oil.
a. FXSTD models, see Figure
1-50. Remove the drain
screws and washers from each fork and drain the
fork oil.
b. All models except FXSTD. see Figure
1-51. Remove
and discard the drain screws and washers from
each fork and drain the fork oil.
4.
Install new drain screws and washers.
a. FXSTD models. apply LOCTITE THREADLOCKER
243
(blue) to drain screws and tighten to 12-18 inIbs
(1.4-2.0
Nm).
b. All models except FXSTD. tighten drain screws to
52-78 in-Ibs (5.9-8.9 Nm).
5. Refer to Table 1-7. Fill the fork with Harley-Davidson
TYPE E FORK OIL (Part No. HD-99884-80).
6. Tighten fork tube caps to 40-60 ft-Ibs (54.2-81.3 Nm).
Old Apr 19, 2009 | 10:35 PM
mgmmgm's Avatar
mgmmgm
Smile fork oil
I think I will just do the SE Heavy and see what that does.
Old Apr 20, 2009 | 07:42 AM
roysays's Avatar
roysays
12.9 oz a side or total?
Old Apr 20, 2009 | 01:35 PM
tlb's Avatar
tlb
Per tube/side so you will need 25.8 oz total= two bottles from the dealer. I have a syringe from walmart to fill batteries with. it measures 2 OZs at a time. I measured with it and with a mark ont he bottle to get the .9 part.
Old Apr 20, 2009 | 06:29 PM
roysays's Avatar
roysays
thanks tlb
one more quick question, the directions say to remove the drain screws, discard and put new ones in....is that really necessary? can't the original ones be reused?
Old Apr 20, 2009 | 06:40 PM
turtle2's Avatar
turtle2
thanks tlb
Yes, I have reused mine four times-still no leaks.
