Bar Question - And first post!!!
Old May 8, 2009 | 09:46 AM
2006FLST's Avatar
2006FLST
Default Bar Question - And first post!!!
Okay first time posting but have been lurking for a while. Question on adding bars. I have added many bars on different bikes before and re-wired etc. However there are many deals out there selling bars with controls and wiring already installed. My question is on these newer bikes (mine is an 06 heritage) is there a way to remove the dash or tank and plug in new wires or do I still need to do the old cut solder and heat shrink method?
Old May 8, 2009 | 11:23 AM
matt816's Avatar
matt816
give hill country customs a call, theyll fix you up for exactly what youre looking for. also no need to solder anymore plenty of good kits out there
Old May 8, 2009 | 12:00 PM
anubisss's Avatar
anubisss
You can get a wiring extension kit as stated above. Just plug the wiring in and heat shrink it as opposed to soldering.
Old May 8, 2009 | 12:14 PM
jeff.georgalas's Avatar
jeff.georgalas
CHIIIITTTTT!!! I read that thread starter and thought I was being invited to the bar to have a cold one!
Old May 8, 2009 | 12:41 PM
2006FLST's Avatar
2006FLST
Thanks for the replies. I will check that place out. I guess my next question is this. Is there a way to disconnect the wires from under the tank to add the extensions. Maybe I am missing something. Like I said I have done this before but all older stuff.
Old May 8, 2009 | 01:39 PM
AK47's Avatar
AK47
Yes! Take the tank off, or move it back to gain access to the wiring, then you will have to disconnect the molex/deutsch connector and take all the wires out of it then add new wire extensions, heat shrink them together, then put the connctors back together and you are good to go.
Old May 8, 2009 | 01:59 PM
2006FLST's Avatar
2006FLST
Great. Sounds like a snap. Thanks. Of course I could look at my shop manual but I am lazy.
Old May 8, 2009 | 11:01 PM
danfrompa's Avatar
danfrompa
Just to be safe. I would remove tank. The wiring has to be tucked under the tank so that it does not touch the engine...etc... Since you have a manual, read the instructions on removing the tank and do it the proper way. There is very little room to move things around without moving the tank.........
Old May 9, 2009 | 06:15 AM
coop57's Avatar
coop57
No need to remove just take the tank loose an block it up.
Be carefull not to damage the cross over tube.
Old May 9, 2009 | 12:53 PM
2006FLST's Avatar
2006FLST
Thanks guys lots of helpful info on here. NOW if someone can give me some money to get new bars and controls
I also need to get a picture of my ride on here somehow.
