Lock for Fatboy?
Old May 10, 2009 | 06:29 AM
coop57's Avatar
coop57
Default Lock for Fatboy?
Can anyone recommend a good way to lock up a Fatboy while on the road?
I am going on a road trip next month and I would like a little more security while sleeping.
I don't think brake locks are all that effective I would like a cable or chain to lock around a pole or tree but with the solids I am not quite sure how?
Looking for ideas...
Old May 10, 2009 | 08:29 AM
Trailfndr's Avatar
Trailfndr
Pt the cable or chain thru the FRAME. Best place is probably right behind the front downtubes. I used to lock mine up that way..and still lock the wifes Deluxe to my Ultra thru that part of the frames on both bikes. Just make sure you use a covered chain or cable to avoid scratches.
Old May 10, 2009 | 08:40 AM
MortgageGuy's Avatar
MortgageGuy
Trailfndr nailed it. Heavy coated chain through the frame is best. They make some nice ones with combination or key locks built in.
Old May 10, 2009 | 05:58 PM
oct1949's Avatar
oct1949
could pull her into the room at night..
just do a search on the subject, U'll find plenty
Old May 10, 2009 | 07:18 PM
BigJoeNY's Avatar
BigJoeNY
Heavy gauge hex chain thru frame to a fixed object with no slack so it's far away from the ground. Makes it harder for the low-life's to work on the lock or chain when it's off the ground. Always leave in well lit areas. Insure her well because if they want it bad enough they will get it. I personally like the Ongaurd Beast 14mm hex chain and lock set.
Old May 10, 2009 | 07:54 PM
coop57's Avatar
coop57
Thanks for the tips guys I have taken three long trips and always worry.
Now that I have her moded out the way I want, I worry even more!
Old May 10, 2009 | 07:55 PM
jimmers1817's Avatar
jimmers1817
I have the Roadlok disc lock and the heavy azz forgetaboutit chain lock and I still can't sleep. You might think I didn't have insurance or something.
___________________
2008 Heritage Classic: His
2008 Deluxe: Hers
Old May 10, 2009 | 09:31 PM
sportyguy69's Avatar
sportyguy69
It doesnt matter if you use a chain or a padlock threw the brake rotor, if they want your bike they are gonna take it. Just hope there is easier prey else where.
Old May 10, 2009 | 10:00 PM
78fxs78's Avatar
78fxs78
I use a Disc lock, I figure its harder to reach it with a Torch, Bolt Cutter or a Saw , they'll have to carry the whole thing away (which they do also), just remember to remove it before you try to drive away.
Old May 10, 2009 | 10:14 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Frame is the most secure place to lock it but in a pinch around the floorboard brackets works too. If you are traveling with others, lock multiple bikes together daisy chain style, or just roll it into the room. Cover it with a Honda cover. I don't cover mine on trips as I don't like to waste space with a cover but I know a lot of people who do. As far as type of lock, get a cable lock (something light). I use a Kryptonite New York lock at home but it weighs a ton so I take a cable lock and lock it togehter with the handcuffs I use to lock my helmet with. So far it has worked like a charm.
