lock stops
Old Jun 10, 2009 | 02:15 PM
hogster1961's Avatar
hogster1961
Default lock stops
Managed to score a nice set of Pro-one triple trees that should be with me shortly...the quandry I have is what type of lock-stops to use,the internal ones recommended by the guys at Pro-one just seem to be a lower bearing cup with a tang that locates in a collar fixed on the bottom tree...all sounds good but I can't see what will stop the bearing cup from turning in the frame neck if some excessive force were applied,ie should the bike fall over(God forbid!)they(Pro-one) say fix it in with Red loctite but I'm a bit dubious/sceptical about that working.
The other alternative is to go with some kind of external stops but that kinda defeats the object of fitting such a clean set of trees..any thoughts/suggestions guys?
jag1886
Feb 14, 2012 04:51 PM
2NAHNTR
Feb 21, 2009 04:07 PM
marksfatboy
Sep 30, 2008 06:45 PM
mrthinkshesfunny
Apr 17, 2008 01:30 PM
traveler
Feb 22, 2007 02:26 AM
