Help needed HELP
Old Jun 13, 2009 | 03:03 AM
Panky's Avatar
Panky
Default Help needed HELP
I have a 2007 night train with 18,233 miles on her and last month I installed a Fuel pak and big sucker with my screamin eagles slip onsand then this month I was getting blow by on my dipstick. I thought it was the temp gauge dipstick just worn out. I replaced with stock and now I see blow by on my head bolts and on my left side primary drive. The gaskets are leaking oil!!!!!
What gives what could be wroung???
HELP
Old Jun 13, 2009 | 03:39 AM
moonlighter64's Avatar
moonlighter64
did you recently service the primary? Engine ?
Old Jun 13, 2009 | 04:20 AM
oct1949's Avatar
oct1949
do u really know where its coming from?
Old Jun 13, 2009 | 08:43 AM
Cheesecake's Avatar
Cheesecake
are you getting any oil in the air cleaner?
Old Jun 13, 2009 | 01:45 PM
Panky's Avatar
Panky
I went through everything this morning. Oil has just started to come out of the lower primary cover bolts and the head bolts..
I think I I have found the problem when I installed my big sucker kit it had two new bolts for the oil ports. So I just used them. Well when I took it apart today I grabb the old bolts to see if there was a difference and the new bolts are 1/2 longer then the stock bolts. There was minimal oil in the air cleaner not like before.
So now the question is.....Did I just cause multiple leaks all over the engine that will continue to leak or did I solve the problem.
The big shitty part is my warranty ran out on 6/9.......4 days ago
67 bobber
May 18, 2007 12:40 AM
67 bobber
May 18, 2007 12:34 AM
67 bobber
Oil Archive (no new posts)
May 18, 2007 12:14 AM
Goodsy
Apr 23, 2007 07:10 PM
Goodsy
Exhaust System Topics
Apr 23, 2007 07:07 PM
