Hard restarting
Old Jul 10, 2009 | 10:25 PM
Stcbob's Avatar
Stcbob
3rd Gear
Default Hard restarting
Hi,
I'm a new owner of an 07 Softail custom. Here's the problem. I start it in the morning, ride about 1.5 miles and stop to get a paper on my way to work. When I try to restart the bike, it often turns over 6 or 7 times before firing up. Any idea what the problem could be? I have an extended warranty so I'm not to concerned, but I don't want to get stranded either. Thanks for any insight you can offer.
Old Jul 10, 2009 | 10:56 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
is it a stocker or are you running some additional compression via pistons or milled heads?
Milled or hi comp pistons at 10:5-1 or beyond go get some comp releases machined into the heads or buy a new starter every year or two.
Is it just a tired old battery that spent the winter not on a trickle charger?
Pull your seat off and check the battery with a multimeter.
Take to dealership if not inclined.
Old Jul 10, 2009 | 11:02 PM
oct1949's Avatar
oct1949
I've read several have had this,,, do a seach and follow up some post and threads to find if anyone got the answer..
I never had this issue... 1st 1k and before stg1, SERT, and Dyno it would turn over 2-3 times after she got really hot, like if I stopped for gas.
But after the work was done haven't had it since..
Old Jul 11, 2009 | 12:58 AM
Steve_In_29's Avatar
Steve_In_29
Mine just did this on me today for the first time so I am interested in what you find out as well.
Old Jul 11, 2009 | 07:59 AM
Stcbob's Avatar
Stcbob
3rd Gear
Thanks for the interest folks. I'll do some more searching on this and let you know what I find out. It is bone stock (except for the bling the PO put on it) Like I say, I have an extended warranty on it, but the dealer I got it from (the only ones in the area I would really trust) is 80 miles away so I really have to have a good reason to go there. I am planning on getting new pipes and a backing plate and getting it remapped. That might straighten it out. I'll keep you posted.
Old Jul 11, 2009 | 08:04 AM
stupid_rope's Avatar
stupid_rope
I have the same issue.
My solution: I slightly open the throttle when I crank it and it fires up.
Old Jul 11, 2009 | 08:45 AM
rbabos's Avatar
rbabos
Originally Posted by Stcbob
Hi,
I used to have that problem with the stock ecm. Best I could come up with is some kind of iac setting quirk. Learned that if it won't fire up within 2 revolutions stop and rehit the start button and it fires right up. Second thing is to give it slight throttle and it will start as well. You could try giving the iac plunger a bath in tb cleaner and see if it frees it up. General symptoms I had were, short ride to get gas or whatever, try to start and it would crank over and over with belching in the exhaust or backfiring. This is caused from not enough air entering the tb to set the idle speed. The iac does that. If it will start with slight throttle application, this will confirm this fault. Even going to tmax I had a couple of instances of this, but since cleaning the iac it has never occured all season.
Ron
Old Jul 11, 2009 | 11:01 AM
softail04's Avatar
softail04
sound like a fi problem
go back to a carb problem solved
Old Jul 11, 2009 | 11:30 AM
tmitchellof PG's Avatar
tmitchellof PG
Check that your battery and ground cable to the frame are clean and tight.
Tom
Old Jul 13, 2009 | 07:12 AM
B.Fighter43's Avatar
B.Fighter43
I agree with Chazmanian first check the battery,My 01 springer did the same thing and i was told that after the first start the battrey was just getting weak and the volts was just not there for the injectors to fire after the bike got warm needed a little more volts.
I even kept mine bike on a tender all the time but the battrey was over five years old.
New battrey and no further problems.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
