Brake Fluids Mix?
Old Jul 23, 2009 | 09:37 AM
jknowlton's Avatar
jknowlton
as everyone stated, flush out, get new lines if you plan on switching back to DOT3/4.
DOT 5 can cause sludge and brake failure when mixing with 3/4, it is silicone based..Usually once you go through it with DOT 5, you def. should not switch back to DOT3/4 because of the mixture that has happened, unless you change out all the lines.
Old Jul 23, 2009 | 10:23 AM
chunks's Avatar
chunks
I could swear I used DOT 5 in my 05 Fat Boy per the service manual.
Did HD switch the fluid they use?
Old Jul 23, 2009 | 11:49 AM
jknowlton's Avatar
jknowlton
I know 07 Softail service manual is DOT 4.
Around 2005 for certain models they switched..Yours I think was DOT 5..switched Softails in 2006.
DOT 4 - For use in '06-later VRSC™, '07-later XL, '08-later XR, '06-later DynaŽ and SoftailŽ, and '05-later Touring models.
DOT 5 - Fits all models (except '05-later Touring models, '06-later VRSC™, DynaŽ, SoftailŽ and '07-later SportsterŽ models).
98hotrodfatboy
EVO
34
Jul 12, 2019 07:07 PM
RENORRIS
Jan 19, 2012 10:19 AM
Sgt_Jim
Apr 5, 2011 09:35 PM
jonnyrotton
Dec 22, 2007 10:42 AM
HDF Tech
Jun 27, 2005 10:58 AM
