DOT 5 Brake Fluid......
Old Jul 7, 2019 | 10:23 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Default DOT 5 Brake Fluid......
Decided to rebuild my front caliper flush the fluid etc etc... Well I didn't have enough DOT 5 brake fluid to complete the job. I had enough to bleed it and everything so but not enough to fill the reservoir. So I went to the local parts store to see if I could find some but AutoZone and Advance Auto parts Don't carry DOT 5 anymore. so, I was wondering what you guys are doing? Are you flushing your systems and replacing with DOT 3 or 4 or are you finding a new place to find DOT 5.....? Definitely curious thanks...
Old Jul 7, 2019 | 10:32 AM
d_slat's Avatar
d_slat
Do NOT put dot 3 or 4 in a dot 5 system. Dot 5 systems often use seals that are not compatible with dot 3 or 4 fluid
Old Jul 7, 2019 | 10:44 AM
98hotrodfatboy
That does not answer my question... I want to know what you guys are doing if you're having a problem finding DOT 5....
Old Jul 7, 2019 | 11:19 AM
larsfum's Avatar
larsfum
I just change the brake fluid on mine. Picked up a 12 oz. bottle of Bel-Ray from Amazon:
Amazon Amazon
Old Jul 7, 2019 | 11:20 AM
fxrs89's Avatar
fxrs89
O'reillys auto parts had Dot 5 on shelf a month ago.
Old Jul 7, 2019 | 11:29 AM
touchdown204's Avatar
touchdown204
HD dealer has it too
Old Jul 7, 2019 | 11:48 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Rob to answer your question I'd get Dot 5 from wherever I could find it.
Even Walmart has it
https://www.walmart.com/search/?quer...eahead=dot%205
Old Jul 7, 2019 | 11:50 AM
texashillcountry
Dirt don't hurt
Advance should have it.
https://shop.advanceautoparts.com/p/...archTerm=dot+5
Old Jul 7, 2019 | 01:58 PM
98hotrodfatboy
Thanks guys I did travel around for about an hour and finally found some at a little mom and pop place. Hard to believe AutoZone and Advance which is owned by carquest didn't have it. tI was shocked... but thank you I just wondering if it's something around here or if it's something that's going on nationally...
Old Jul 7, 2019 | 02:31 PM
Jackie Paper's Avatar
Jackie Paper
They have it at my local Carquest Advance Auto here in VA
