effing horn
Old Aug 9, 2009 | 01:21 PM
plopper's Avatar
plopper
Default effing horn
hi all, i have 2008 fatboy and when i went to use the horn yesterday it sounded like a muffled duck, any ideas before i jump into this one thanks in advance..
Old Aug 9, 2009 | 01:25 PM
cuda67bnl's Avatar
cuda67bnl
Try cleaning the connections.
Old Aug 9, 2009 | 01:40 PM
RKKY's Avatar
RKKY
Take some silicone spray to it. Usually will fix it right up. If it doesn't work then go to the connections.
Old Aug 9, 2009 | 01:45 PM
jimmers1817's Avatar
jimmers1817
Have you gone through any deep water. Happened to mine once. Took the horn off and dried it out. Back in business.
Old Aug 9, 2009 | 09:29 PM
m i k e's Avatar
m i k e
submarine harley????
whats the modification???
Old Aug 9, 2009 | 10:06 PM
oct1949's Avatar
oct1949
Any kids around that might stuff rags in there.. dont ask how I know..
Old Aug 9, 2009 | 10:27 PM
CyclChyc's Avatar
CyclChyc
Thats the case with my 05 Deluxe. I just figured it was an age thing and I just needed to replace it. Now I am thinking that since the previous owner kept it outside that weather may have effed it up?
Old Aug 9, 2009 | 10:34 PM
anubisss's Avatar
anubisss
Spray wd 40 in it or let it dry out on it's own. I assume it got soaked recently. Also, check your ground for the horn, My ground came off and It sounded like an ant yelling for while until I figured it out. Motor mount bolt fell off and the ground was attached to it.
Old Aug 9, 2009 | 10:42 PM
tlb's Avatar
tlb
For the last two years I have cleaned my connectors, sprayed silicon in it, and checked and double checked everything. I could get it to work again for a few months.
A couple of months ago I had a car merge into my lane, I hooked the horn and blah. I went to advanced auto, purchased the low tone replacement horn. 16 dollars and a direct replacement that works perfect.
Old Aug 9, 2009 | 11:24 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
My stocker sounded like a ducks last quack prior to tasting the Butchers steel blade.
Since I'm an obnoxious azzhole I went whole hog.
Airhorns. Metal arts. Loud? Very.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
