Bobtail rack
BUT it works perfect with the Sundowner seat that I use for 2 up. That seat has a regular bolt that comes out. So I can get a long enough bolt to work.
And yes, you have to drill the holes over your plate.
Chop On,
Robert
Anyone have pic's of where you need to drill? The rear fender doesn't need to be removed, does it? Gawd, I hope not!
Otherwise the holes are extremely difficult to drill from the top with normal hand tools. But if you have a slim drill or a very long bit, or bit extension you can get at it from underneath. The trick is to get a small hole in the right spot from above to use as a pilot for the full sized drill to follow when you come up from below.
I use some masking tape and a Sharpie marker to mark out where the holes needed to be. Then used a small drill on top and the bigger longer one from below to get it done.
It was almost a wasted effort in the end, because I replaced the tail light with the tri-bar and had to use a an adaptor bracket to get it to fit.
But on the plus side the stock tail light bracket is not rated for loads exceeding 10lbs. of load on the rack (according to Harley). Given the plastic nature of the light assembly I can understand why.
But when you install the tri-bar you need to use a steel bracket that's substantially heavier duty and even if the load limit is still listed at about 10lbs. I'll bet good money it can easily handle far more weight than I would feel comfortable with hanging out back that far.
