performance dl's Question
Old Dec 1, 2009 | 09:29 PM
USAF ATboyLo's Avatar
USAF ATboyLo
6th Gear
Arrow performance dl's Question
i just recently insalled my exhaust. and am installing my intake this weekend. i was wondering about this flash download that Harley is being very pushy about. is it necessary or are they full of it. Thanks
Old Dec 1, 2009 | 09:40 PM
oct1949's Avatar
oct1949
Heres a old post about why we need to tune our bikes,,,, and it still is the same way today............
12-03-2005, 08:57 PM
Terry1955
"Administrator & Troll Slayer"
2000 Harley Davidson Screamin Eagle Roadglide
Why EFI Vehicles Need To Be Tuned
For all the people that don't quite understand why you need a Race Tuner (SERT) or Power Commander (PCIII USB) for your Harley please read this. This was not written by Harley (who makes the SERT-Race Tuner). I favor the Race Tuner but will concede that the PCIII is also a good piece of equipment. But PLEEEEEEEEEEEEEASE...Don't use the HD download
The need for "re-mapping" a fuel injected bike only arises when internal and/or
external engine components are replaced with non stock components, i.e. air
cleaners and exhaust systems. When components are changed on an engine to
any non stock or "performance" part you alter the way that engine moves air in
and out, thus altering the Volumetric Efficiency. If the V.E. is altered the stock
ECM fuel settings continue to deliver fuel at a base-line rate unaware that the air
delivery has changed. With the fuel delivery unchanged and the fact that this
engine is receiving more air there is a lean condition created that will most likely
cause engine damage due to higher heat levels in the combustion chamber. A VTwin
engine is just that, two separate cylinders in a "V" configuration which
generally speaking will cause these cylinders to flow air at a different efficiency
rate. This effect is mostly caused by a non tuned exhaust system that flows air at
different rates from front to rear thus changing the volumetric efficiency.
With the advancements and complexity of today's fuel injection systems
simplicity is not necessarily advantageous. The need to compensate for fuel
delivery to a modified engine ideally would be performed by the original engineer
or programmer of the ECM since they would be the one most knowledgeable on
this system. Since this avenue is not available to the average consumer, a
method of putting a "Band-Aid" type programmer (HD Download) to compensate
for the modifications is the easiest solution, however it is not necessarily the best.
Installing a "Band-Aid" on a system with this complexity can sometimes create a
whole new realm of problems that the original engineers could not have
anticipated.
The Dyno Jet Power Commander unit with it's 126 fuel adjustment cells and 126
spark timing cells offer simplicity that cannot always compensate for the high
demands of a modified V-Twin engine. Especially when the cylinders have a
different V.E. rate, this also offers a "Band-Aid" solution at best.
The H-D EFI Race Tuner Kit offers 220 Volumetric Efficiency adjustment cells for
each cylinder along with an Air Fuel Ratio (AFR) adjustment table that has an
additional 120 cells for a total of 560 fuel adjustment cells. There are also 220
cells for each cylinder to compensate for spark timing, fuel enrichment cells for
cold start and cranking enrichment for easier starting. With these extra tables and
cell adjustments there are over 1000 adjustments that can be made. Also
consider the advantages with having the ability to set your idle mixture as well as
idle speed and having access to your own rev limiter which is adjustable from
4000 to 7500 RPM.
__________________________________________________ _________________
The Dyno Jet Power Commander does not alter the stock rev limiter. That is why
many people use the Stage 1 Download along with it. The Stage 1 Download
raises the rev limiter to 6200 RPM.
Heres the full thread to read for Ur info......................... Yes U need to read through it..
https://www.hdforums.com/forum/elect...-be-tuned.html
Old Dec 1, 2009 | 09:44 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
The download is wothless in most people's opinion. Pony up[ a few extra $ and get a tuner. Power commander, sert, sest, tts, thundermax, etc. etc. etc...There are countless threads on this subject, fand everyone has a different opinion. I had the download and air filter and aftermarket pipes on my bike when I got it and it ran like crap. Put a power commander and got a dyno and it was a day and night difference.
Old Dec 1, 2009 | 09:46 PM
Rockyriver's Avatar
Rockyriver
I second the Power Commander on being good. Have no experience with the rest.
Old Dec 1, 2009 | 09:49 PM
VTwin-Goodies
Former Sponsor
I forgot to say that with the addition of a high flow filter you do need to remap your EFI somehow or else it will run extremely lean. The mixture needs to be richened up. More air needs more gas to burn.
Old Dec 1, 2009 | 09:51 PM
VTwin-Goodies
Former Sponsor
Old Dec 1, 2009 | 09:57 PM
USAF ATboyLo
6th Gear
i apreciate all the good info. guess i should of done my research on this forum a little more in depth before posting.
Old Dec 1, 2009 | 10:32 PM
oct1949's Avatar
oct1949
Amazeing, u actually are saying that U need to know something about what Ur saying before asking us a question about what U don't know....
Old Dec 1, 2009 | 11:01 PM
SoftailSlim's Avatar
SoftailSlim
Power Commander V or Thundermax w/autotune are good units. Power commander seems to be most common, but if I ever need to replace my Thundermax w/autotune I'll install the same thing again. They have great customer service when you get ready to install yourself or make tuning changes later. Super people at Zipper's.... HD downloads are junk!!!
Old Dec 1, 2009 | 11:38 PM
USMC2010's Avatar
USMC2010
I haven't had my wide glide tuned on a dyno and most likely won't. I did have the HD download with my intake and exhaust change and my bike runs fine. The factory has to do two things and not in any specific order, they make bikes that run well and they must meet EPA regulations. A dyno tune will get the maximum perfomance out of your bike but to say that a factory download is junk is a bit of a stretch too.
joey883
Feb 10, 2013 09:53 AM
DHart
Oct 1, 2009 10:22 AM
John_dyna
Mar 28, 2008 03:07 PM
jjsj38
Feb 1, 2008 12:41 PM
HDF Tech
Mar 19, 2006 01:46 PM
