Need Help!!
Old Dec 10, 2009 | 03:51 PM
deadeye's Avatar
deadeye
Originally Posted by Citoriplus
Your better off getting the Harley part for it, even if its going to cost you about $50. Otherwise your going to need to do some work on the tank and fuel rail fittings and where your going the parts might not be so easy to find.
BTW that 'blue button' is the disconnect, push it in and the line (end now) will come off.
If I were you I would keep the rest of that line in your tool box, in a zip-loc bag. To get it off lift up on the chrome ring at the tank end while pushing up on the line and it will come right out, its like an air line connector.
Unless your planning on staying in Japan permanently, it will come in handy for draining the tank when you ship the bike back.
The parts will be easy to find in Japan for an 06 Harley, but they will cost 3X more. So, buy what you need before you come over.
Old Dec 10, 2009 | 03:55 PM
Nightking's Avatar
Nightking
That pressurized line needs to be factory or aftermarket. I definitely would not use hose and a clamp on it.
Old Dec 12, 2009 | 09:07 AM
WVNightrain Rider's Avatar
WVNightrain Rider
The part number you need from HD is 62900-01A, it is item 30 on page 132 / 133 in the parts book. I broke mine last year too, they are pretty weak. If I am not mistaken it was a $47 part. You can not buy just the small piece that broke, they only sell the single piece from the tank to the throttle body (about 6").
The only good thing is it only takes 30 seconds to install.
Old Dec 12, 2009 | 01:11 PM
mimo's Avatar
mimo
There you go!
Thanks brother,
Mimo.
Old Dec 12, 2009 | 05:55 PM
Other Sheep's Avatar
Other Sheep
Just so you know, my son has had his hose with clamps on for about two years and ten thousand miles and it works fine. There is not that much pressure on the line with our small fuel pumps. Not trying to make up your mind for you. Just letting you know that a hose and clamps work fine.
Old Dec 12, 2009 | 06:04 PM
oct1949's Avatar
oct1949
ching chong da fong dong...$50 buck.... interruption: buy it here and save money...
Ripit
Canada
Jan 28, 2018 04:40 PM
Biketom02
Engine Mechanical Topics
Apr 14, 2017 12:15 AM
micahpop
May 7, 2011 05:04 PM
moraink
Exhaust System Topics
Dec 9, 2009 11:56 PM
jimchopper85
Jul 7, 2008 08:17 AM
