Throttle / Idle cables
Old Dec 28, 2009 | 10:10 AM
twisted125's Avatar
twisted125
Default Throttle / Idle cables
I ordered a set of Magnum Throttle and Idle recently and took what Hill Country Customs told me as far as the length goes. My bike is a 2007 Standard, and HCC told me I would need 38". This is to go to 1.5" risers and 14" Burlys. After installing, these things are LONG. I ran them how they were, and they start up near the risers, and fall out into a long droop to get to the throttle. Just in trying to take out some slack, I ran them under my neck, toward the left, then turned up, and over the neck to the right and headed up to the throttle and they seem to be just the right length. My throttle seems to move smoothly, and I made the adjustments to tighten the slack I felt in the grip, now its nice and tight. Are there any opinions on running them this way? There are no hard corners in the lines. I think it may even look cleaner run this way. I would zip tie them away from where the steering will turn in and pinch, but felt the need to ask. Ill try to take some pics tonight to better illustrate what Im talking about. My bike is back together and it would chap my *** to have to take it all back apart to send them back.
Old Dec 28, 2009 | 10:35 AM
Mike NY's Avatar
Mike NY
Send them back and do it right. Don't settle and try to make it work...
Just my opionion...
Mike
NY
Old Dec 28, 2009 | 10:43 AM
twisted125's Avatar
twisted125
when you turn your bars all the way to the left, how much play should you have in your throttle / idle lines?
Old Dec 28, 2009 | 06:39 PM
m i k e's Avatar
m i k e
you should have a little play , dont want em rubbin or pulling from no slak,
you also could run em through triple tree to take up slak too
any pics????
fyi i gat 4" risers ,16" apes & i believe 34 1/2 throttle/idle
Old Dec 28, 2009 | 08:32 PM
sancho_panza's Avatar
sancho_panza
Twisted, I don't think you should worry about them if they're not binding and not flopping around and you like the way they look. On my dyna, I ended up with cables way too long from Magnum, and I ran them through the triple trees. It actually looks pretty good, and they work great. >1 year with no problems.
Old Dec 28, 2009 | 09:19 PM
twisted125's Avatar
twisted125
thanks for the replies guys. Ill try running them through the trees and will post pics when I can get out there.
Harley Rookie
Apr 5, 2014 09:51 PM
civilbob
Jun 24, 2013 08:54 PM
butch1
General Topics/Tech Tips
Jun 8, 2012 02:11 PM
scampman_73
Jun 20, 2009 05:01 PM
OneBlackFly
May 10, 2007 02:27 AM
