So we were slow at work so I took the day off and did some work to the bike that I have been trying to find time for. I shaved the tail light / license plate bracket since I made my own axle mount bracket, lowered the rear suspension, stripped the belt guards, relocated the rear turn signals, installed the detachable hardware and crossbones sissy bar ($15 swap meet find), and installed the Heavy Breather intake. I'm really liking the improvements. The only uncertainty I have is with the intake. It doesn't rub my leg, but it definitely touches it. I'll have to give it a while to decide if I really like it or not. It looks like a totally different bike. I still need the pad for the bar, but all in all I like the progress. What next....?
Im diggn it!
I just got one of those x bones sissy bars, not even close to cheap as you got yours, Did you have to get the signal relocation kit to make it work?
Ray
Reason: spellin
The tire probably looks that way because I took a couple of trips around the block (clockwise) this evening after I made the mods. COLD! As for the signal relocation, I don't think the sissy bar would have attached without doing it, but I don't like the Harley brand relocation kit. To me it looks cheesy with the straight bolt setup. There was a post on here a while back where someone moved their stock signals and mounting posts back and got the detachable stuff to work fine and maintained the factory posts. I might switch to that for looks, or better yet install the alloy art strut mount ones and call it good. I'm still undecided.
I am with you on the HD relocation kit (cheezola). But for the same money I found the Kuryakyn kit that looks like it would be pretty okay looking.
The thing I like is I don't have to modify anything and can put it all back if I need to.
