Power Commander - Autotune?
Old Feb 22, 2010 | 03:35 PM
Tao3535's Avatar
Tao3535
Default Power Commander - Autotune?
I'm looking at purchasing new pipes and I talked to two different places about the tuning. The dealer told me if I ever change something later like the air cleaner I'd have to come back and have it re-tuned. A custom shop nearbye told me they would install the Power Commander Autotune which doesn't have to be retuned if a change out a part. Any thoughts or recomendations on this?
Old Feb 22, 2010 | 04:03 PM
beaureed445's Avatar
beaureed445
You're in Wisconsin.....Call Jamie at Fuel Moto USA. He's in your neck of the woods, and is great....he'll lead you in the right direction.
Old Feb 22, 2010 | 10:18 PM
Rakthi's Avatar
Rakthi
+1 on Jamie ... also ask him about the TTS ...
Old Feb 22, 2010 | 11:21 PM
Toneaero's Avatar
Toneaero
Canned maps works too...just not optimal. If you have the extra money to throw at it, then go with any kind of autotune fuel/air controller.
Old Feb 23, 2010 | 03:12 AM
maddox13's Avatar
maddox13
What are canned maps? and i have a similar question on this topic, i read in this months american iron that 08 and 09's because of the o2 sensors due not need remap for arlen ness big sucker, that the o2 sensors will correct it, if so i am wondering if they will correct for pipes as well, fyi i think i saw another thread on this same topic
Old Feb 23, 2010 | 06:21 AM
Toneaero's Avatar
Toneaero
Canned maps are what's preinstalled on the tuners. Usually submitted by other users on dynos or from the company. For instance, im not the only person in this world with a 96ci motor with Big Radius pipes and HD heavy breather. I would then use a "canned map" of this setup that someone previous had submitted.
For the o2 sensors picking up changes...yes they will pick up changes but changing both the exhaust and the air cleaner is out of the computer's range to compensate. Close loop vs open loop.
Old Feb 23, 2010 | 07:16 AM
MCSarge's Avatar
MCSarge
Any changes that the computer compensates for will be back to the factory perameters that are set in the computer. Around 13. something, thats why people go with an aftermarket tuner to get the fuel ratio around 14.6 for a cooler running motor and more power. They will most of the time make adjustments to lean out the cruising range to get you better mileage on the highway. Contact Jamie and he will provide you with more information than you probably want to know
Old Feb 23, 2010 | 08:37 AM
sgod1100's Avatar
sgod1100
ya got that backwards...around 13.something is what you want to be at...~14.6-14.7 is stoichiometric ratio..which would make you run much hotter considering all of the gas is getting burnt up. The lower the number the more gas is left over to cool the engine
Old Feb 23, 2010 | 08:57 AM
Colin1966's Avatar
Colin1966
another option to check out is the Thundermax w/autotune, thats what I am running.
Colin
Old Feb 23, 2010 | 11:00 AM
Ash16's Avatar
Ash16
Just chaged my stock football breather for a Roland Sands Design Venturi 5 and bought the PCV from Fuel Moto USA. Intstalled both of them, started her up , and rode. Easy to do and runs great.
