Disassembling Forks (quick help if possible)
Old Feb 22, 2010 | 05:39 PM
Schaub85's Avatar
Schaub85
Default Disassembling Forks (quick help if possible)
I'm disassembling them to Pcoat them. but I cant for the life of me get them apart. The manual just says "remove dust cover and dust shield." the cover is the rubber thing, that was not problem but the shield is an aluminum thing that doesnt look anything like the diagram.
WHAT DO I DO?
Old Feb 22, 2010 | 05:42 PM
DyNaBoB's Avatar
DyNaBoB
did you take the allen bolt out of the bottom of the slider???...........if so do a hammer slide and they will pop right off
Old Feb 22, 2010 | 05:46 PM
DaveFLSTFB's Avatar
DaveFLSTFB
+1 on taking the allen bolt out
Old Feb 22, 2010 | 05:47 PM
Schaub85's Avatar
Schaub85
thanks for the quick response, i dunno if it helps tho
heres where i am...
Old Feb 22, 2010 | 05:50 PM
DaveFLSTFB's Avatar
DaveFLSTFB
There is an allen bolt inside where the axle sits... did you take that out?
DyNaBoB's Avatar
DyNaBoB
yes now take the allen bolt out of the bottom you will see it in a hole in the bottom of the slider (its really tight use an impact gun if ya have one )once you have it out do a sliding motion and slide hammer it, they will come apart
Old Feb 22, 2010 | 05:53 PM
Schaub85's Avatar
Schaub85
ok yeah it is deff tight, ill let ya know....
Old Feb 22, 2010 | 06:03 PM
Schaub85's Avatar
Schaub85
well sure enough the one we have is a half inch to short. And the guy that goes to the PC just left. Looks like im runnin to sears and doin it tomorrow. Thanks alot for the quick response times guys.
Old Feb 22, 2010 | 06:06 PM
DyNaBoB's Avatar
DyNaBoB
cut the elbow off a allen (so its straight) and put it in a socket
Old Feb 22, 2010 | 07:52 PM
stratplexi's Avatar
stratplexi
If I remember correctly, its a 10mm and needs to be fairly long. I used an impact wrench on mine.
