side mount tag bracket
Old Mar 2, 2010 | 09:13 AM
skyline090's Avatar
skyline090
Default side mount tag bracket
Need some help from those with side mounted license plates.
I'm looking for (but can't seem to find) a cheap curved axle mounted bracket w/a tag light. The only one i found is from Kuryakyn, and its over $100. (overpriced IMO) I want to chop that ugly stock plate bracket on the Deuce, and retain the stock brake light. Everything I'm finding is either a stand alone bracket, or bracket with a brake light.
Do i have any other options other than Kuryakyn?? Pics/links would be much appreciated!
Old Mar 2, 2010 | 09:23 AM
Shovelhead Jack's Avatar
Shovelhead Jack
Search ebay. You can find a good steel side mount with taillight for cheap.
Might not find a curved one though. I got the KuryAkyn one and the taillight is too small so I yanked it and mounted an LED cat eye to the bracket.
Old Mar 2, 2010 | 09:59 AM
beasleyiv's Avatar
beasleyiv
I grabbed one of these and some LED bolts:
http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
LEDs:
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_2175wt_899
Old Mar 2, 2010 | 10:10 AM
skyline090's Avatar
skyline090
Originally Posted by beasleyiv
I like those bolts.. great idea! I didnt know they made something like that. How did you run the wire? Are the wires pretty well hidden from view?
Old Mar 2, 2010 | 10:36 AM
beasleyiv's Avatar
beasleyiv
I haven't installed yet, but figured I'd shrink wrap the wires together and run along the swingarm. Should be able to keep it tucked away.
Old Mar 2, 2010 | 11:03 AM
OhioSkully's Avatar
OhioSkully
I got one from LM cycles on ebay and they have a website but they are actually cheaper by cpl bucks on ebay still only $50 bucks and has held up great. Offer it in black or chrome and has an led strip for the plate light not sure if its what your looking for.
http://www.lmcycles.com/shop/catalog...V8&shop_param=
Old Mar 2, 2010 | 11:07 AM
OhioSkully's Avatar
OhioSkully
note mine was not curved and don't think they offer curved at the site i listed but on how to run the wiring i tucked it behind the swing arm put a 3m wire sticky tab back there and wire tied it cant even see it and then up into the battery fuse area and tapped into the connector for the rear brake lights and hooked the wiring to the wire that runs the license plate lite by popping the connector apart and soldering my wire to the existing wire that goes to the back of the bike worked like a charm.
Old Mar 2, 2010 | 07:02 PM
catmechanic's Avatar
catmechanic
https://www.hdforums.com/forum/softa...ate-mount.html
Here is a link to the one I made from stuff laying around the shop. It was a breeze to make, looks good (IMHO), and didn't cost a dime. (frame was $6 at autozone, skull bolts were $19 at the stealer). You could use those same LED bolts or just make the bracket a little bigger in the direction you would like the light, and get the LED or standard lights from o'reilly, autozone, napa, J&P, etc.
SoCalSoftailSlim
Feb 19, 2013 05:31 PM
JohnFlorida
Nov 20, 2011 08:27 AM
rexel
Sep 4, 2011 11:11 AM
variablek
Apr 1, 2009 10:21 AM
creekhed1
Aug 27, 2008 11:41 AM
