Even though the tread looks good, my bet is that you need a new front tire. The treads will cup a little and get unbalanced. www.bigmikespinstriping.com
I had that issue on my 06 Heritage too and was told by the dealer that they couldn't stop it. When I replaced the front tire, wobble was still there, so in my case, that wasn't the problem. I took it to another shop and they tightened the neck bearing bolt and it was gone.
I have a 2007 Heritage softail..How do i tighen the neck? Someone said there is a bolt to tighen on the bottom of the neck...Does anyone of a video for this?
There is a chrome cover on top of the bolt. It is round. You can take the cover off by unscrewing it. Then you have access to the bolt. To get a torque wrench on it you will need to remove the bars from the risers.
