2007 flstc - wind deflectors
Old May 5, 2010 | 05:18 PM
Hellas_Manny's Avatar
Hellas_Manny
4th Gear
Question 2007 flstc - wind deflectors
Guys I desperately need your help.
I own a 2007 Heritage Softail Classic (FLSTC) with the detachable windshield and the passing lamps.
A month ago I acquired a set of HD wind deflectors (part number: 58125-90B).
The local Harley engineers insist that the said deflectors could not be installed on my bike because of the existence of the detachable windshield and the passing lamps.
Since I am ready to enter the mental hospital could any of you US experts advise your Greek friend if the said deflectors actually fit on my ride and if so are there any instructions available apart from the HD instructions which are completely vague and incomplete.
Thanking you in advance
Manny
Old May 5, 2010 | 06:37 PM
nhall's Avatar
nhall
6th Gear
Default wind deflectors
hey hellas manny. i just put them on my 08 flstc should be the same.first make sure the bent part on the side is pointing back and the bent part on the top is pointing forward.remove the lower bolt first and install deflector put bolt back in only acouple of turns to make sure it is threaded right. then do the top bolt.you might have to apply some pressure to line it up snug up the top bolt then the bottom then tighten them up.maybe some one here can tell you how much to torque them to. norm
Brukus Motorcycle Parts
Apr 10, 2012 12:52 PM
stevereno
Dec 5, 2011 05:08 PM
roofgunner
Softail Parts
Feb 28, 2009 07:01 PM
salty01
Sep 18, 2008 06:22 PM
garyparky
Sep 6, 2007 08:09 AM
