HD pullback risers on Fatboy Lo
Old 05-25-2010, 01:41 AM
spelk3's Avatar
spelk3
spelk3 is offline
You will need to loosen the clamps for the brake line and may want to change the routing of the clutch cable (in-front rather than behind the bar), but you will not need to replace any cables or the front brake line.
Old 05-25-2010, 09:23 AM
ex99125b's Avatar
ex99125b
ex99125b is offline
Thanks for the real-world experience...I'm going for it!
Old 05-25-2010, 07:40 PM
kd5hrm's Avatar
kd5hrm
kd5hrm is offline
As above, thanks for the real-world answer. I've always worked on dirt bikes and ATVs and never really gave a damn what they looked like when I was done...as long as it worked. I'm a little pickier about this bike.
Old 05-25-2010, 08:18 PM
jbg's Avatar
jbg
jbg is offline
I'm in as well. Gonna pick up the 4" riser this weekend. Thanks all.
Old 05-25-2010, 11:00 PM
paud's Avatar
paud
paud is offline
Originally Posted by beasleyiv
Yep, well you might need to loose the clamps on the front brake line. Then take the bars out of the stock risers, lay them on the tank (on a towel), remove the risers, replace with new risers, insert bars in said risers, install caps, adjust bars, enjoy.
Is it possible to post a pic?
And did the new position make it more comfy?
Old 05-25-2010, 11:28 PM
beasleyiv's Avatar
beasleyiv
beasleyiv is offline
Didn't take any pics. It really is simple. There are 2 or 3 rubber clamps that hold the brake line to the back of the nacelle cover area, and to the bottom of the head.
Yeah, they helped get the bars back a bit.
Old 05-25-2010, 11:37 PM
jbg's Avatar
jbg
jbg is offline
What part number were the risers?
Was it this one? http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old 05-26-2010, 05:49 AM
Viking66's Avatar
Viking66
Viking66 is offline
Might as well change out the riser bushings to some good ones while you are in there!
Old 05-26-2010, 06:30 AM
RuMbLeStRiP's Avatar
RuMbLeStRiP
RuMbLeStRiP is offline
*VIKING66* What kind of bushings are you talking about? Is it a big difference from stock? what is the main change when you do that?
*Anyone who's got this setup* i'm hesitant on getting the 4" pullback risers because i don't know if it will be enough pullback. How much more comfortable does it make the riding position? How much more do the bars really pull back with the risers?
Also, has anyone put the 6" pullback risers on their fatboy lo and not had to change the brake line or any of the cables or wiring?
THNX
RuMbLeStRiP
Old 05-26-2010, 09:02 AM
Colin1966's Avatar
Colin1966
Colin1966 is offline
I have the 4" riser on my 09 Fatboy, it makes for a more comfortable riding position.
With the 4" you do not need to change any cable but you WILL have to if you go with the 6". I have the stock bushings and no issues.
This is a fairly straight forward mod just read the advice posted and COVER YOUR TANK with a towel for protection.
ride safe
Colin
Quick Reply: HD pullback risers on Fatboy Lo
