Heat Shield
Old Jun 3, 2010 | 10:52 AM
mikef's Avatar
mikef
Default Heat Shield
I want to get my dad a Heat Shield for fathers day.... He has a 2007 Softail Deluxe. Does anyone have any thoughts as to which of these would be better and why? I am going to order a plain one as I dont think he will like the custom studding.... Thanks guys.
http://www.rjsoriginals.bizland.com/newSelect0010.htm
http://www.capt-itch.com/
Old Jun 4, 2010 | 12:48 AM
mikef's Avatar
mikef
Bump.... Anybody have any comments? Thanks guys.
Old Jun 4, 2010 | 02:17 AM
Bluehighways's Avatar
Bluehighways
I installed a set of the Küryakyn Saddle Shield Air Deflectors on my bike. I think I paid about $40 or $50 for the ones that go on a Softail.
I was pleased with how easy they were to install, they're actually kind of hard to see unless you get up close to the bike and even when you can see them they're not objectionable in my opinion. Best of all they seem to work! On an 85+ degree day at a stop light I can feel a whiff of heat coming off the engine, but no more or less than any other bike I've owned.
All this being said; I have also changed the exhaust (V&H BSL), and the A/C (SE), then added a HD Oil Cooler, and have reprogramed the ECU with the TTS System so all these things add up. I'm not sure what the Heat Shields by themselves would do for you.
Old Jun 4, 2010 | 02:22 AM
deadeye's Avatar
deadeye
I had some on my train for a short time. I never measured the temperature but they did block heat. However, they seemed to make the oil tank much hotter by trapping heat around it. I took them off.
Old Jun 4, 2010 | 02:50 AM
Hot's Avatar
Hot
Default RJ Heat Shield
I have a studded pair, work well. R J very helpful, good guy.
Thanks
Rod
Old Jun 4, 2010 | 02:52 AM
tk353's Avatar
tk353
seems it would block the air flow. better option is get rid of the heat. maybe a fuel management. The hard type that are smoked seem ok
Old Jun 4, 2010 | 09:31 AM
mikef's Avatar
mikef
Thanks for the input guys.... His bike is all stock and he really doesnt like to do anything to it.... Here in California I think the bikes do run a little hotter due to the are set up to run lean.... I dont think he will change that.....
I will look at the other heat shield mentioned above too.....
Does anyone else have one and is happy with it.... so far the input seems to be that it doesnt do much....
Old Jun 4, 2010 | 09:48 AM
hogbutt's Avatar
hogbutt
I have the Küryakyn type also. They do a great job redirecting the heat away from the boys. But, it does seem to push it to my calve area.
Old Jun 4, 2010 | 09:51 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Support forum sponsors. Captain Itch is a forum sponsor and makes a high quality product.
Drew
Old Jun 4, 2010 | 02:49 PM
mikef's Avatar
mikef
Drew
Good point... I always try to support the forum sponsors. I just ordered it from Captain Itch.....
Thanks to everyone for the help....
