Upgrading the Twin Cam 88B
Old Jun 9, 2010 | 03:17 PM
dwyleecoyote's Avatar
dwyleecoyote
Default Upgrading the Twin Cam 88B
Hello all, I am obviously new here, but have read through a few times...
I have a 2003 FLSTC, 88B motor, mostly stock, just has gear drive cams with Andrews #260 cams. My mechanic just informed me that the rotor has destroyed my crank at the young age of only 49,000 miles. So the day has finally come that the motor comes out, and the inches go in... I told him I was thinking in the direction of 103 inches since a crank would need to be purchased anyway.
What I am looking for is advice on any aspect of this, questions I should ask my mechanic, or anything I should or should not do for this build, as I have no experience with this kind of thing.
Thanks in advance!
Old Jun 9, 2010 | 03:40 PM
mike06train's Avatar
mike06train
You could go bigger then 103 if your going to bore and stroke it. What exactly happend to the crank?
Old Jun 9, 2010 | 09:20 PM
dwyleecoyote
The compensator has come loose twice now. Quite a few miles went by the first time, the second time my new, and much better, mechanic tried a new compensator and rotor, but did note that with the wear in the crank spline that it may or may not survive.... it did not survive. It ate another rotor, and he says the damaged crank can not be repaired- the splines are beat up from the rotor and compensator being loose. I do not want to go so big that reliability becomes an issue, so I thought 103 was about tops for that. I don't race or drive it hard, but I do appreciate some nice response on the throttle.
Old Jun 9, 2010 | 10:30 PM
oct1949's Avatar
oct1949
go to the tech area and read up on what others are doing.... lot of good builder out their and kit online,,, just read, research and ask question and go from there...
Old Jun 10, 2010 | 04:35 PM
kiwideuce's Avatar
kiwideuce
i just did mine recently,i went to 95" with andrews 37 cams
Old Jun 10, 2010 | 08:17 PM
dwyleecoyote
I talked to my mechanic today. He is going to get me pricing on some options... He is a little hesitant to set me up with a 103 kit because he doesn't like the length of the stroke. He is going to look at some options for a larger bore and a shorter stroke. He is talking about using either S&S or Dark Horse. He will be getting a crank that is welded- said the pinned ones aren't strong enough. He is suggesting an S&S 585G cam(I already have the gear drive), a 45mm Mikuni carb, and he will be re-working the heads and valves in his own shop. I told him to also quote me a 6 speed gearset for the trans, and see about sending the jugs out to be diamond cut.
Old Jun 10, 2010 | 09:28 PM
NightTrainRob's Avatar
NightTrainRob
I just did the 95" on my bike and loving it so far, got a friend that has a 131" done by cycle rama and very reliable
EasternSP
Dec 22, 2011 06:13 PM
Chad263
Jan 23, 2011 09:00 AM
1bagman
Aug 13, 2010 02:21 PM
krisdenrand
Aug 19, 2009 06:26 PM
rome304
Jul 28, 2009 11:11 AM
