Lighting high beam issue
Old Jun 15, 2010 | 04:22 PM
lu420prez's Avatar
lu420prez
Stage II
Exclamation Lighting high beam issue
Hey guys and gals, I just bout my first bike, its 02 Deuce....great bike, but i am having a lighting issue. I replaced the fuse and the low beam light works fine....but I have no high beam......can any one help of suggest what to do to fix it?
thanks
Lu420prez
Old Jun 15, 2010 | 04:24 PM
AR-15 DEUCE's Avatar
AR-15 DEUCE
Ah how about replaceing the light bulb
Old Jun 15, 2010 | 07:03 PM
xwhyz1959's Avatar
xwhyz1959
Or at least rule out the lamp by ohming out across the terminals.
Old Jun 15, 2010 | 07:35 PM
chrome-dome-dave's Avatar
chrome-dome-dave
Harley has a problem with the headlamp connector going bad and they sell replacement ones. Im not sayn this is your prob, but I kept blowing bulbs every other day, then I replace the connector per a hd tech and it hasnt blown in 4 months. But its cheaper to remove the buld and see if the elemnt is broken 1st.
Old Jun 15, 2010 | 11:55 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
One way to keep the bulb from buring out early is to make sure you have clean and corrosion free connectors and make sure you put a little bit of dielectric grease on the terminals.
Using a little of that on connections will keep any moisture that manages to get into it.
Because ANY corrosion in the connector, or any connector for that matter will raise the current loading of that circuit and in lighting circuits will cause bulbs to burn out prematurely.
Old Jun 27, 2010 | 07:34 PM
lu420prez's Avatar
lu420prez
Stage II
Thumbs down Still no resolve with High beam
I replaced the light bulb, tried switching the wiring to the no stock bulb, I have power to the switch but lose power to the headlight on the high beam....I am new to bikes so is there a wiring harness under the gas tank or where to the wires go from the high beam switch. Any help would be great before I take the bike apart in pieces......the bike is an 02 Duece......thanks guys!
Old Aug 7, 2010 | 02:47 PM
jessebradley's Avatar
jessebradley
Stage IV
Did you ever get this fixed? I just bought a 96 Fatboy that has the same problem... When I switch to highbeam though I hear a relay click and all lights flicker momentarily. This process keeps repeating with no lights ever staying on.
Old Aug 28, 2010 | 11:54 AM
jessebradley
Stage IV
Default Found the problem on mine
Got to looking around and removed the dash on my 96 Fatboy. The Highbeam indicator wire had been pinched and grounded out to the dash bolt. Some liquid tape and insured that it was all clear of pinch points when I put back together.
Chris Topple
Electrical/Lighting/Alarm
Feb 11, 2020 11:21 PM
edthesniper
Jul 10, 2012 06:53 PM
TurkeyRun
Feb 23, 2012 06:29 PM
dadofsix
Aug 9, 2007 10:58 AM
deadeye1340?
Feb 28, 2007 07:50 AM
