How do headlights work?
Old Feb 23, 2012 | 10:25 AM
TurkeyRun's Avatar
TurkeyRun
Default How do headlights work?
I know that sounds like a silly question. I've got something weird going on here and I think it may just be a bulb. But, I've got about 6 weeks left on my warranty so before I go dive in, I thought I'd ask. Here's what is happening:
Riding home the other night, I flipped my high beams on. Just about messed my shorts as I got almost nothing! Went back to low beams, all is well. Current status is, with the low beam on, I can see down the road, and my passing lamps are on. Turn on the high beam, passing lamps go out, and I get this "halo" of light that is totally black in the middle.
OK, me thinks, "somehow the headlamp got out of adjustment - need to take a look". I backed the bike up from the garage door, and put a piece of tape on it per the owner's manual dimensions. Low beam: check. High beam: I can't even tell if it is in alignment as I have NO light in the middle of the beam, just this HUGE circle of light about 15" across. Hurmph.
So, if this is as simple as changing the bulb, I'm on it. Just seems really strange. I've done nothing electrical to the bike since I put the GPS mount and XM radio antenna inside the fairing about 20K miles ago when I first got it. No troubles until about a week ago.
Oh yea, 2010 Ultra, stock headlamp.
Thoughts?
Old Feb 23, 2012 | 10:45 AM
relli's Avatar
relli
sounds like bulb
Old Feb 23, 2012 | 11:02 AM
mkguitar's Avatar
mkguitar
the "high beam" and the "Low beam" have separate filaments, it's like 2 bulbs in the same housing.
they can burn out independently.
the position of each filament in relation to the reflector is also important, if a filament gets shifted "out of focus" it may produce light, but in a position where the reflector cannot project the light forward in a focused beam.
many riders rewire so that he spot lights stay on with the high beam, and H-D now sells a kit if you hate $30 and want it out of your wallet.
many States allow high beam in the daytime, which i use.
it evens out the wear between the low and high beam filaments ( maybe)
the bulb is easily replaced, you may want to look at the sylvania silverstar at your local auto parts store
mike
Old Feb 23, 2012 | 11:09 AM
TurkeyRun's Avatar
TurkeyRun
Thanks guys
Yea, the simplest solution is usually best. What's weird is, I've had headlamp bulbs fail before, but not like this. It has been my experience that when one fails, that perticular mode (high/low) goes out completely. Never had one act like this and put a big black spot in the middle of the beam like that.
I'll run out at lunch and grab a bulb from NAPA.
Old Feb 23, 2012 | 03:31 PM
TurkeyRun's Avatar
TurkeyRun
Yup - bulb
I actually had bought a 2-pack of Silverstars last time I got headlamp bulbs so I didn't even need to go fetch one.
Really weird though, never saw one "go sideways" like that. Usually a bad bulb is a bad bulb - pretty binary.
Old Feb 23, 2012 | 05:03 PM
mac1911's Avatar
mac1911
The perfect time to replace the headlamp with an HD LED. Best money I have spent on my bike.
Old Feb 23, 2012 | 06:25 PM
jjnoble's Avatar
jjnoble
There is a troll in the housing that holds a candle, sometimes a lot of them. The more candle power the better, you know how it is.
Old Feb 23, 2012 | 06:27 PM
TurkeyRun's Avatar
TurkeyRun
Except in the really old bikes, like on the Flintstones. They had a goofy lookin' bird holding the candles.
Old Feb 23, 2012 | 06:29 PM
TurkeyRun's Avatar
TurkeyRun
Yea, that's on the "someday list". My Road King has LED turn signals and tail light. Really, really bright. Probably do all of them - headlight, tail light, passing lamps, and turn signals. before my ride to Milwaukee next year.
Garemlin
Oct 26, 2012 04:54 PM
MILLER41143
Sep 13, 2011 01:49 PM
jawja
Electrical/Lighting/Alarm
Aug 15, 2008 10:18 PM
titus3:5
Jan 18, 2008 02:52 PM
Azrael
Dec 23, 2007 06:34 PM
