Head Light Mod
Old Sep 13, 2011 | 10:30 AM
MILLER41143's Avatar
MILLER41143
Default Head Light Mod
I have used the search tool but cant find my answer so i was gonna throw this out there and see what i find out.
I just installed the HID light on my 10sg from ddm tuning, i installed this same light on my 09 vrscf but did a mod where i put an inline splice on two wires and it enabled hi+lo to be ran at the same time but only low by itself
i always turn my brights off when passing cars but when driving at night on Kentucky backroads every bit of light helps.
Thanks for any help
Old Sep 13, 2011 | 01:20 PM
journeyman's Avatar
journeyman
Thanks for any help
I'm not sure what kind of HID unit you have, but as I understand they do not really have a separate lights for the Hi beam/low beam.
There is actually a short start up time needed to reach full strength, so that would be counter productive when traveling at high way speeds to switch lights.
How the hi/low thing works is, the bulb slides in/out to change the beam focus.
Old Sep 13, 2011 | 01:49 PM
MILLER41143
the last setup i had had 2 bulbs and that worked great because the low was always running so when u flipped to high beam the low was already running at full power
but on this new setup your right there is one bulb for both hi/lo
alamedavic
Jan 27, 2015 03:31 PM
TurkeyRun
Feb 23, 2012 06:29 PM
durrett syndrome
Jun 12, 2010 08:05 PM
bulldogmoe7
May 29, 2008 04:16 PM
Azrael
Dec 23, 2007 06:34 PM
