hi-beam lamp
Old Aug 8, 2007 | 09:49 AM
dadofsix's Avatar
dadofsix
Default hi-beam lamp
Well, I've lost my hi-beam again. Since I usually ride during the day with the hi-beam on this is a huge safety issue. It fails without warning (and yes, I always check b4 I ride). I replaced this lamp for the second time only two months ago. No problems with the low beam though.
Does using the hi-beam all the time degrade its life expectancy? If it were a short, why doesn't it go Immediately and why isn't the low-beam affected? The bike is still under warranty but damn, I hate taking it there unless I absolutely have to.
Any help would be appreciated.
<><Peace
Old Aug 8, 2007 | 09:57 AM
Hdbiker1450's Avatar
Hdbiker1450
Default RE: hi-beam lamp
It may be a short. I experience the same type issue not too long ago, except in reverse. I had no passing lamps or low beam, only high. Problem ended up being a crimped wire coming from the switch housing. I just loosened it a bit, fiddled a few seconds, and had lights again. Haven't had a problem since. But you are right. I check the damned things every time now!
Old Aug 8, 2007 | 12:34 PM
Waltman's Avatar
Waltman
I replaced the stock lame yellow bulb in my 07 FB with a PIAA bulb which iswhite and brighter. Great illumination at night. 8K miles after andstill goes strong and I also use the high beam during day time riding which is 95% of that mileage.
Old Aug 8, 2007 | 03:05 PM
clueless's Avatar
clueless
I assume you know not to touch the bulb ever but use a tissue (non-aloe type). to hold the bulb. or you can clean with an alchol wipe before and let dry then install.
the oils when heated with the High Beam will cause a hot spot and hence early bulb burn out.
Old Aug 8, 2007 | 03:37 PM
dadofsix's Avatar
dadofsix
Is there really that much difference in the heat from the hi-beam as opposed to the lo-beam?? BTW I never touch the glass bulb when installing it. And why does the hi-beam a;ways burn out and not the lo-beam -- or both.
<><Peace
Old Aug 8, 2007 | 05:29 PM
Waltman's Avatar
Waltman
One bulb, two filaments (high / low), different wattage, one hotter (+brighter)than the other. In all the years I have been riding (25) and 6 bikes, only once I had toreplace a bulb, and it was the low beam bulb (burnt at around 12K)in my '99 Busa (separate bulbs in that baby) . You seem to have a wire problem. They should not burn every 2 months or so.
Old Aug 9, 2007 | 10:43 AM
dadofsix's Avatar
dadofsix
I first noticed that I had lost the hi-beam while doing tight turns on the painted pavement used by the MSF classes at our local community college.
I suspect, but have no way of knowing for sure, that a wire got pinched in one of the tight turns. I dont't see any creases or crimps though.
This is kind of frustrating for a simple (hah!) problem.
<><Peace
Old Aug 9, 2007 | 10:58 AM
Spike_96's Avatar
Spike_96
A short in the wiring would not cause the hi-beam to fail, but it would cause the fuse to blow. Is the bulb really dead? or is there no power going to it. Connect a voltmeter to the hi-beam and ground wires. move the bars (or the headlight harness)around, see if the voltage drops out or drops down. Low voltage to the bulb can cause premature failure.
Good luck.
SnoRider
Jul 11, 2016 01:24 PM
ggerline
Jul 22, 2013 05:15 PM
tcastle64
Jul 31, 2012 07:22 PM
jawja
Electrical/Lighting/Alarm
Aug 15, 2008 10:18 PM
Garemlin
Jul 31, 2008 01:53 PM
