Rocker tail light
Old Jul 11, 2010 | 03:51 AM
finnrocker's Avatar
finnrocker
Default Rocker tail light
I installed side mount license plate holder and now the original (center) tail light looks just stoopid. Anyone changed that to something else?
I'm gonna keep the original fender for now and I was thinking of installing Sparto-style (as on Street bob) tail light. Or do you guys have other great ideas?
European models have tail and brake light on the same lamp on fender and turn signals are just turn signals. I also don't want to put the tail light to the side with license plate.
Old Jul 11, 2010 | 06:05 AM
HD100's Avatar
HD100
I put on the Kellermann 1000DF, they include turn signal, brake-and tail light in a small housing, looks very clean.
Old Jul 13, 2010 | 08:58 AM
finnrocker's Avatar
finnrocker
I was thinking those also, but I'm gonna keep the original fender and I think that all those covers (for example Kuryakyn License Plate Mounting Hole Cover) are ugly and don't make the bike look any better than keeping the original tail light...
Did you need to make any changes to bikes electrical system or did you just join the wires to original wires?
Old Jul 13, 2010 | 11:05 AM
HD100's Avatar
HD100
No, you don't have to make any changes to the electrical system, just connecting the original wires.
The only thing is, if you use 4 LED turn signals, then you have to use a resistor.
What do you think of closing the holes with some chrome screws or these allen hole plugs? A friend of mine did it, looks not bad.
Old Jul 16, 2010 | 10:09 AM
finnrocker's Avatar
finnrocker
Not sure yet. I was thinking of using some spike bolts, but chromed allen bolts would be fine too.
Old Jul 16, 2010 | 11:13 AM
Kowan's Avatar
Kowan
I used a chrome emblem meant for a Ford Harley truck and a plug button chrome for a 1/2 inch hole to cover the holes left.
The emblem isn't a perfect match for the tank emblems but looks close enough for me.
Old May 6, 2014 | 12:15 AM
HDFan0611's Avatar
HDFan0611
Hi, I have the kuryakyn side mount license plate…but I have not hookup the wiring yet…
to connect to the original wires… did you connect under the fender or under the seat?
whats the easiest way to find the wires under the seat… I'm going to remove the seat to install a load equalizer… thanks.
Old May 6, 2014 | 04:33 PM
HD100's Avatar
HD100
Hi, I made a connection outside the fender.
Old May 6, 2014 | 05:15 PM
HDFan0611's Avatar
HDFan0611
OK…thanks.
Cool looking bike…
Do you have more pictures? I'm trying to figure out what you did… I found the wiring diagram of the fender…and I can re-route the middle channel and make a connector like you did… see pic.
Old May 7, 2014 | 05:26 PM
HD100's Avatar
HD100
I used completely new wires starting from the connector. (No.5)
Sorry, I don’t have more pics.
