Primary Lube level
Old Jul 22, 2010 | 07:04 AM
cigarowens's Avatar
cigarowens
Default Primary Lube level
Hi All,
I changed the Primary lube in my 01 Fat Boy last night (installed Red Line V Twin Primary Lube) and I'm a little concerned about the fill level. The shop manual says use 26 ozs but then says to fill to the bottom edge of the clutch housing. I ended up putting 29 ozs in and I still was a little below the housing. I checked the lube that came out (which was professionally installed) and it measured close to a liter.
I took a short test ride and everything seemed great but I was wondering if I should have added the last three ozs of lube or am I making a mountain out of a mole hill?
Old Jul 22, 2010 | 07:59 AM
asm481's Avatar
asm481
mountain out of mole hill.
Old Jul 22, 2010 | 08:06 AM
deucer02's Avatar
deucer02
I believe your fine where it is now. I fill until it touches the the bottom edge of housing, with the bike on a lift.
Old Jul 22, 2010 | 09:58 AM
nikonf8's Avatar
nikonf8
Default primary
I go with the 26 on mine
Old Jul 22, 2010 | 10:56 AM
FastHoss's Avatar
FastHoss
I put in 26 and don't worry.About 2 1/2 quarts on the oil fill,half way on the stick.22 in the trans.
Old Jul 22, 2010 | 11:35 AM
Jackie Paper's Avatar
Jackie Paper
Default Level
You are fine at 26. It would lubricate at 13 since it looks like a shower in there since the chain dips way down at the tensioner. The extra is more for cooling and reserve lest it happened to start leaking in its old age. Most people put too much since they misread the level in the manual. You do not want the actual clutch plates under the oil. Check out my pictures and you will see what I mean if you have not looked inside or have a service manual
Old Jul 22, 2010 | 11:59 AM
never say never's Avatar
never say never
well i dont run a softail but on my eg i remove the inspection plate and fill the primary(while the bike is on the kick stand)until it runs out the inspection hole.put the covers on and go.on my dyna i just give her 1 quart.
Old Jul 22, 2010 | 02:27 PM
klf33's Avatar
klf33
I had similar thing on my 01 FXST last month, the book said 3/4 of a quart would work but it took 1.3 quarts to reach the clutch lower edge (with bike on stand of course) .
bike running fine since then, had some bleeding between the engine/tran behind the rear cylinder (under oil tank) but that has always been there .
Old Jul 27, 2010 | 07:46 PM
skannner's Avatar
skannner
I use lucas 80/90 in my 99 heritage and dump in the whole thing. 3 qts in my oil tank castrol syntec
Old Jul 27, 2010 | 08:19 PM
DyNaBoB's Avatar
DyNaBoB
1 QT ATF in my primary....smooth as buttah
