Belt tension tester
Belt tension tester
In browsing through the HD catalog, I notice they have a "belt tension tester tool" listed. Is this something I need to add to my Christmas list? Being an old chain guy, these belts are still new to me. How often do they require adjustment? How do you check the tension with this tool? I like to do most of my own maintenance work, but I've just never had any experience with the belts...
Thanks!
Jeff
Thanks!
Jeff
RE: Belt tension tester
ORIGINAL: twowheelsforever
I've seen those too, and wondered if they are necessary or not. Seems like you could get close enough just pressing on the belt with your fingers, and measuring with a ruler, but maybe someone has some insight...
If you are going to do your own rear tire changes you should have the tensioner gauge. A belt too tight will be hard on bearings, and too loose you run the risk of jumping teeth.
Here is a link to how to use the tensioner.
https://www.hdforums.com/m_132315/tm.htm
Regards,
Bill
Regards,
Bill
