belt tension
Old Aug 19, 2007 | 07:26 PM
bulldogmoe7's Avatar
bulldogmoe7
Default belt tension
does the drive belt loosen after a while. my neighbor has a 2006 rkc and we were looking over his bike and the drive belt had about 2in-3in of play. he has 9000 miles on it. is this normal? do they stretch over time?
Old Aug 19, 2007 | 07:35 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Default RE: belt tension
Yep... HD makes "BELT TENSION TOOL " # 40006-85
Applying 10 lbs pressure you will see the adjustment through the lower belt guard
Old Aug 19, 2007 | 07:50 PM
Retired_Ted's Avatar
Retired_Ted
The belt stretches VERY little, if at all. Sounds like someone tried to adjust it as if it were a chain. Tighten it up if it isn't already trashed.
Old Aug 19, 2007 | 10:02 PM
nb472's Avatar
nb472
Use a belt tension gauge as described in the manuel ( with a rider on bike for mine) However I feel a little looser than the book says is better. Easier on seals and bearings.
Reaper22
Sep 9, 2011 08:07 PM
Dale_K
Jul 8, 2011 06:43 PM
seoris
Oct 16, 2010 06:41 PM
RockDog
Jun 6, 2010 01:49 PM
spizzyman
Oct 11, 2008 07:56 PM
