Ape install Help!
Old Aug 5, 2010 | 12:44 PM
chunks's Avatar
chunks
Default Ape install Help!
Nothing like tackling a job you've never done before, and when you tear into it, what you find is NOT what the tutorials and instructions tell you
I'm putting 12" fat mini apes on the 09 Fat Boy.
I have wiring extensions and the instructions that came with show female connectors on the wires coming from the bars.
So does one tutorial I viewed on this forum.
In my bike the connectors dont resemble the photo's at all.
Can someone tell me how to disassemble this and put in the wiring extensions? I have one of these on the wire bundles coming from both sides.
Old Aug 5, 2010 | 12:47 PM
roadkinging's Avatar
roadkinging
if you look at backside of the plug in ur hand you willl find a quick-release ****.... one for each wire.....
Old Aug 5, 2010 | 12:54 PM
Cheesecake's Avatar
Cheesecake
http://www.moccsplace.com/images/harley/hbar/hbar.htm
this help any?
CC
Old Aug 5, 2010 | 01:04 PM
ROMPUS's Avatar
ROMPUS
Sorry but I have not done that yet but really want to,but will say however that the blue fatboy is beautiful,I love the blue.
Old Aug 5, 2010 | 01:34 PM
chunks's Avatar
chunks
No quick release ***** that I can see...
heres the other side...
Old Aug 5, 2010 | 01:35 PM
SuspendedUser's Avatar
SuspendedUser
i just did this last night...
first insert a pair of needle nose plyers into the little holes in the center of the connector and pull... that plate you see in the picture will come forward, DONT pull all the way out, you will be able to see the tips of the pins... then with a paper clip insert "carefully" and NOT all the way into the little hole on top of the pin and pull the pin out from the back "slowly"
hope it helps, make sure you write down cable color and pin number for each one before you remove them, the pin number is on the back in really really small print.
Old Aug 5, 2010 | 01:36 PM
SuspendedUser
i had no problems with this, im having MAJOR PROBLEMS with my risers... damm...
quick tip, running the wires trough the bars with some very small chain and gravity worked like a charm.
Old Aug 5, 2010 | 02:09 PM
mike06train's Avatar
mike06train
Look inside the plug. Under every pin is a very small tab. Reach in with something small like a screwdriver for eyeglasses and lightly press the tab down and pull the wire out from the back. DON'T FORCE anything. When your done the pin just slides back in the way it came.
Old Aug 5, 2010 | 02:24 PM
dusty2221's Avatar
dusty2221
Like posted above, you need to remove the wires from the plug. Now that you have the bottom unsnapped, flip it back to the top (the side you plug in) and use a small pick to pry up the tiny tab on the backside pressing against each wire end. You will pull the wires out of the plug one at a time. Very simple once you figure out how to hold your head.
Old Aug 5, 2010 | 04:46 PM
jimmers1817's Avatar
jimmers1817
This is the correct procedure. When you push the paper clip into the round holes at the top and apply a little pressure you're feel the wire release give. Just slide the wire out the back. Some of them will be easy and some may be a pain. Just gotta get the paper clip in right.
