oil change
Old Sep 7, 2006 | 12:42 AM
ELAMARZ's Avatar
ELAMARZ
Stage III
Default oil change
Is there a secret to changing the oil , I took off the plug, but only a small percentage of the oil came out.
Do i have to lift the bike or use a pump.
Old Sep 7, 2006 | 12:49 AM
lapisblue's Avatar
lapisblue
Default RE: oil change
Yeah, you need to turn the bike completely upside down and then shake it back and forth. Sometimes it takes a lot of shaking to get it all out.
ORIGINAL: ELAMARZ
Old Sep 7, 2006 | 12:51 AM
Firefox's Avatar
Firefox
sure you got the right plug?
Check your owners manual. You may have droped the tranny oil. Just a guess without knowing what plug you pulled.
Old Sep 7, 2006 | 12:54 AM
HDWG's Avatar
HDWG
Big Kahuna HDF Member
I have heard of folks running dry........If the bike was cold, it takes awhile for the oil to drain......make sure there is nothing pluging the drain hole....just let it sit for awhile and see if the puddle or, pan gets alittle more full.
Old Sep 7, 2006 | 05:19 AM
millzog's Avatar
millzog
Did you take off the filler cap. Maybe theres too much suction for it to flow ? [sm=confused06.gif]
Old Sep 7, 2006 | 07:10 AM
hdpig's Avatar
hdpig
LOL
Old Sep 7, 2006 | 07:18 AM
PWHOG's Avatar
PWHOG
[quote]ORIGINAL: lapisblue
[quote]ORIGINAL: ELAMARZ
[sm=happybounce.gif][sm=happybounce.gif][sm=happybounce.gif][sm=funnypostabove.gif]
Old Sep 7, 2006 | 09:31 AM
xxxflhrci's Avatar
xxxflhrci
I'll bet you took one of the casting plugs out of the bottom of the engine.....Only about 8 oz of oil came out, right? If so, that's not where you drain the oil on a TC Softail. The oil drain plug is in the on the right side of the frame where the frame and swing arm meet. You take it out with a 5/8 socket.
Old Sep 7, 2006 | 12:30 PM
billnourse's Avatar
billnourse
ORIGINAL: xxxflhrci
This is my bet also. Wrong plug.
If you are going to be doing routine maintainance, you really need to get a service manual.
Regards,
Bill
Old Sep 7, 2006 | 02:41 PM
wvmel's Avatar
wvmel
Stage II
While we are on the subject...
Just bought used 2004 Deuce, have the owners manual but no service manual yet...it is ordered.
As I did in Sportster, I'll use 20W50 Amsoil as engine oil and primary chain case oil. But I am not clear on "transmission" lubricant. As you all know, maunal calls for various Harley products by number.
Is 20W50 syn good for all three spots, or should transmission get something else.
Thanks,
