More Power
Old Nov 2, 2010 | 11:26 AM
dortiz's Avatar
dortiz
Default More Power
Just curious if anyone upgraded the 88 with 95 kit. If so about how much is the cost with parts and labor and was it worth it.
Thanks,
Dave O.
Old Nov 2, 2010 | 12:06 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
I just did this about two months ago. The big bore kit was about $700. If you are doing this you might as well do cams as well. I already had cams. i did the labor myself so that was the cost for me plus the oil to fill it back up. UI kept stock heads. there are so many otions it will make your head spin.
Drew
Old Nov 2, 2010 | 01:06 PM
Shakeydeal's Avatar
Shakeydeal
I paid ~2200.00 for parts and labor. This included cams, pistons and SE heads. I thought it was money well spent.
Shakey
Old Nov 2, 2010 | 01:11 PM
dortiz's Avatar
dortiz
You are close by. Where did you have it done.
Thanks!
Old Nov 2, 2010 | 01:25 PM
shineybike's Avatar
shineybike
About $1,200 for parts with jugs, cylinders, andrews cams, pcIII, some gaskets. $300 for the install by an indy. Nice boost in power.
Old Nov 2, 2010 | 01:34 PM
nikonf8's Avatar
nikonf8
Default build
you wont get the full benefit if you do not do the heads they make a big difference, if your going to do it go all the way
Old Nov 2, 2010 | 01:59 PM
dortiz's Avatar
dortiz
Looks like the price difference between the two folks above was also doing the heads then. I agree, do it all at once.
I need a Christmas bonus : )
Old Nov 2, 2010 | 05:39 PM
Night Stalker's Avatar
Night Stalker
Hey Dortiz... check out T-Man Performance. He has some really good kits. You get to choose your cams, and he offers heads with his kits. He has dyno sheets available as well. FYI! Let us know what you decide to go with!
http://www.tmanperformance.com/
Old Nov 2, 2010 | 06:00 PM
mike06train's Avatar
mike06train
You can get a good 95" kit for around $500.00. Thats for the jugs, pistons, and gaskets only. As far as power gains for a big bore only without head work or cams, maybe 1 hourse power per cubic inch with a really good tune.
Old Nov 2, 2010 | 07:18 PM
beaureed445's Avatar
beaureed445
How far are you from Bethlehem, PA? Contact Dave Stoddart @ JD's Cycleworks....he'll set you up right!
