Another clutch adjustment question
Old Jan 21, 2011 | 07:54 AM
Yuma Jack's Avatar
Yuma Jack
Question Another clutch adjustment question
Good Morning. I have a question for the experts before I adjust my clutch this morning (first time). After adjusting the clutch, can I check it without starting the bike? Can I just put the bike in first gear and push the bike while holding the clutch lever in? I am not sure if the motor must be running to check this.
Thanks in advance.
Old Jan 21, 2011 | 07:56 AM
Chief101's Avatar
Chief101
Follow instructions on this thread.....works for me.
https://www.hdforums.com/forum/trans...-easy-way.html
Old Jan 21, 2011 | 08:00 AM
Yuma Jack's Avatar
Yuma Jack
Thanks Chief101. That is the procedure I printed out and was going to use. My question is for after the adjustment. I want to check to make sure It's not draging or ? Do I need to run the bike to check or can I just push it in 1st gear with lever in?
Old Jan 21, 2011 | 08:04 AM
Chief101's Avatar
Chief101
To be honest, I cant tell with mine not running. I always check mine by taking a short spin to see that the lever adjustment is where I want it, and that there is no slipping with the clutch. I dont think you can tell with the bike not running.
Old Jan 21, 2011 | 08:06 AM
Chief101's Avatar
Chief101
One other suggestion.....at first I was over concerned and too critical when I tried to adjust my clutch. I made it far more difficult than it actually is and worried over it too much. Follow those instructions, take a spin and I think you will be happy. Also.............as an aside, use a good quality lube in your primary and tranny and it will make a lot of difference for you.
Old Jan 21, 2011 | 08:07 AM
Yuma Jack's Avatar
Yuma Jack
That's what I was afraid of. It's 8 degrees where I am at right now. I think I might put this project off till spring.....
Thanks Chief101
Drnapalm
Aug 6, 2019 05:37 PM
hdfozz33
Apr 12, 2018 06:43 AM
Knutson Boltz
Apr 30, 2015 06:30 AM
mehurr
Dec 28, 2010 03:48 PM
UltraKla$$ic
Mar 12, 2007 09:04 PM
