Noob Question
Old Feb 9, 2011 | 09:25 AM
gfergtr74's Avatar
gfergtr74
6th Gear
Default Noob Question
Never had a bike before that I cared whether it was clean or not. This one is different, '06 softail standard. Before this years riding season goes into full swing, i would like to really clean the bike up, in particular the motor. What products do you guys use to clean up the cylinders, cases etc? I want something that will remove old road grime but not mar up the chrome if it gets hit with over spray.
Old Feb 9, 2011 | 09:54 AM
SMF's Avatar
SMF
I use the pig snot or what ever its called and pledge on the rest
Old Feb 9, 2011 | 10:06 AM
wildrooster's Avatar
wildrooster
+1 on pledge didn't believe it until I tried it
Old Feb 9, 2011 | 10:07 AM
02heritage's Avatar
02heritage
Look at the S100 products. That make several that will help get everything clean especially the motor. Once it is clean, I normally just use ONR (Optimum No Rinse) on the paint. Put on a layer of sealant and you are good to go for several months.
Old Feb 9, 2011 | 10:24 AM
gfergtr74's Avatar
gfergtr74
6th Gear
Thanks guys. I will give all of your suggestions a try. I had heard about people using pledge before but was always a little skeptical of this.
Old Feb 9, 2011 | 10:38 AM
Dirty Fxstd's Avatar
Dirty Fxstd
im not sure about pledge on the motor..... someone said scrubbing bubbles cleans up that grey engine pretty good. the engine is in need of a good cleaning on mine also since most of last season was spent barhopping instead of traveling, the bike got a lil funky.....hehehehehe!
Old Feb 9, 2011 | 10:55 AM
wildrooster
Pleadge on the paint seat and leather items works like a charm and You have the lemon smell all day I was using invisible glass until someone pointed me to pledge.
Old Feb 9, 2011 | 10:59 AM
SMF's Avatar
SMF
Yea dont use the pledge on your engine its for the shiney parts and paint hahaha
Old Feb 9, 2011 | 02:22 PM
Swilkins's Avatar
Swilkins
+1 on the S-100 for engines. Used it on mine. Spray on, rinse off blow off with air
Old Feb 9, 2011 | 02:56 PM
SuspendedUser's Avatar
SuspendedUser
Hot Damm! that pig looks like it had a rough night!
